Hotrodders Bulletin Board
#1
82 camaro z-28 , t-350 question
i bought a 82 camaro z-28, with the motor and trans already out of it, well i'm in the process of rebuilding the motor, and am alittle leary about the trans, the guy i got the car off of said the trans sticks in first gear, now i've heard of getting them flushed and they work fine after that , but i have no personal experience with that theroy has anyone heard of that or should i rebuild???
#2
350 turbo question
#3
re: 350 turbo question
I'm going to move this to the "Transmission" forum for some better replies from the experts.
Mark
Lets just hope the "change" that we think we are getting does not end up being just "chump change"! |
#4
That year Z28 should have a overdrive automatic I believe, not a Turbo 350. I would go ahead and rebuild it ... if it was me. Especially if the Z28 was to be a KEEPER. Why take the chance and have to pull it back out ??
I went to the school of hard knocks ... where the tuition is high but the retention is exceptional ! |
#5
Camaro transmission
First it would be wise to identify the transmission correctly so you know exactly what your dealing with. Even though it may be a turbohydramatic 350 it may be a "C" model that had converter lock up. This is important in ordering parts, a converter or rebuild kit. Northern automotive sells engine and transmission kits for just about anything you can imagine from a powerglide to a allision 6 speed. Good company to deal with. Also the T-350 transmission was used by Chevy, Buick, Olds, Pontiac, Cadillac ETC. All were specifically programed for stall speed, rpm shift point range and shift timing depending if the trans was behind a Big V8, Small V8, Six or four Cylinder engines. This is good info to know to see if this trans will work correctly behind what ever engine you plan to use.
* my Quote: If you Fail to plan, you will plan to fail. |
#6
1st thing I would check is to make sure that the modulator valve has vacuum going to it.............if the vacuum line had gotten disconnected, they wouldn't shift.....properly anyways.
#7
Any idea how many miles are on it?...I would tear the pan off and see how much sludge is in the bottom. If the fluid looks nice and red, I'd throw it in, make sure your vac line is hooked up good and see how it goes!
#8
the car has 72,000 original miles, not sure if the tranny was ever replaced, haven't pulled the pan off yet |
#9
i don't know this yet the motor is not in the car yet either is the tranny, i was just trying to avoid putting it in , to find out its not working and have to tear it out again |
#10
are there numbers to find out what tranny it is, i also have another one that came out of a 79 chevy van that had a 350 in it ( that is where the 350 for the camaro came from) but it has a 9 inch tailshaft not the 6, which is no big deal i can have the drive shaft cut |
Back to top |
Similar Threads for: "350 turbo question"
| newer sbc 350 to older turbo 350 | yragat | Transmission - Rearend | 8 | 10-20-2007 07:52 PM |
| Turbo and external waste gate question. help please | beemdubya | Engine | 2 | 11-21-2006 07:35 AM |
| 305 vs. 350 question | DesertPanel | General Rodding Tech | 4 | 10-16-2003 08:19 PM |
| 350 sbc HP/TQ question | stfinney | Engine | 10 | 03-04-2003 02:49 PM |
| 350 turbo or 400 turbo? | nd500 | Transmission - Rearend | 2 | 02-21-2003 08:25 PM |
