350-turbo question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2006, 05:40 PM
350-turbo question
This might be a stupid question, but i am trying to remove the governor out of my 350-turbo transmission. Does it just pull out or is there a trick to it?
i have the cover off already. Any info will be helpful. thank you.
Old 05-12-2006, 05:49 PM
Jmark's Avatar
It should slide right out, unless the case is scored and its catching on a groove. Try pulling a little harder and rotate it some, the gears are angle cut.
Mark
Old 05-13-2006, 10:03 PM
Jeeper426's Avatar
Automotive LTD Technition
okay i'm a rookie when it comes to transmissions, what purpose would removeing the governer have i'm curious
Old 05-14-2006, 09:58 AM
Jmark's Avatar
I'm hoping he wants to remove it to clean it, change the springs or weights. Taking it out and leaving it out would stop the shifting completely.
Mark
Old 05-15-2006, 10:07 AM
Jeeper426's Avatar
makes sence, I've heard of people removeing one of the springs in the governer for a harder shift, but what i was wondering was, if you removed a governer spring, wouldnt you reduce the lifespan of the transmission? or would it just shift harder than normal
Turbo 350 mtuck Transmission - Rearend 1 09-03-2004 10:45 AM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 07:48 AM
305 vs. 350 question DesertPanel General Rodding Tech 4 10-16-2003 08:19 PM
TURBO 350 or 700R4 jeff germano Transmission - Rearend 17 08-31-2003 05:30 PM
350 sbc HP/TQ question stfinney Engine 10 03-04-2003 02:49 PM
