350 turbo shifter linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2011, 09:09 PM
alright so i got a 79 firebird and i rebilt the transmssion and now im reinstallin it.. well had to buy a new shifter linkage cuz i broke the old one. i put it all tgether but had to run a bolt strait thru shifter on tranny to shifter cable becouse the linkage parts r missing to run to the lock on the steering wheel.. well its accurate at putin in gear besides 1st. p r n d 2 all go into gear but i pull it all the way down and it cant find first i have to manuelly put it in 1st by gettin under the car which is a pain becouse im runnin a manuel valve body.... does nebody kno if the cable its self adjust or if u can adjust the cable how? thanks...
AOD Shifter Linkage (B&M 40496) Nitrospud Transmission - Rearend 0 09-14-2009 08:00 PM
C6 shifter linkage help? Steve-0321 Transmission - Rearend 3 02-09-2006 12:08 AM
Shifter Linkage 1slick1 Transmission - Rearend 4 11-03-2005 02:39 PM
Hurst Shifter Linkage Schoust Transmission - Rearend 5 02-02-2004 11:04 PM
shifter to tranny linkage jum Transmission - Rearend 0 11-09-2003 11:05 AM
