350 turbo takes off in 2nd - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2013, 03:10 PM
stanjr41's Avatar
What in the hell is going on here? I post a simple question and it end up with an argument between members about who knows what about governors.I have been trying for a year to get a simple answer or suggestion to my problem and this is what happens;I don't know who to believe. There has to be someone out there who knows enough about transmissions to give me a reasonable explanation without starting a war between members. So, once again my problem is that when my trans. is in drive it leaves in 2nd gear,bypassing 1st completely.If I shift it manually it works ok. I have checked the linkage,and readjusted it(both kickdown linkage and shift linkage),the vac modulator(even replacing it) checked all vac lines for leaks, the governor, and whatever else I could do externally. I pulled the pan and replaced the filter and checked all bolts and linkages,nothing hanging up,all moving freely. Please; someone help me out!
Old 03-09-2013, 04:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If you have checked all the listed items , all was fine as listed, then it is time to remove the valve body.
Check gaskets for correct orientation , check accumulator piston in valve body, check valves for free movement, check the springs for broken ones
Old 03-09-2013, 07:15 PM
rick 427's Avatar
Last journal entry: 33 WILLYS
Stan,let me throw this scenerio at ya. I got bit on this before. I'm checking the movement of the valve in the gov.when i depress the weights, to see that the valve moves up and down,and is seems ok, BUT,later I find out,it is NOT making it's full travel in the bore,giving me a mis-diagnosis that it's good.Sure enough,2nd gear starts are the result.You might want to look at it again.
The Following User Says Thank You to rick 427 For This Useful Post:
runn141 (03-10-2013)
Old 03-10-2013, 07:34 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would also verify the modulator valve is free and moving the full stroke of the bore
Old 03-11-2013, 08:53 PM
2nd gear starts
what happens when you take off in drive 2.second gear from a dead stop does it drop to low?
Old 03-14-2013, 04:51 AM
SSedan64's Avatar
If above checks out.
Intermediate clutch clearance may be too tight.
Was this a fresh build or old trans?
T-350 takes off in 2nd gear stanjr41 Transmission - Rearend 11 03-06-2013 05:45 PM
82 elcamino slips when maually put in 1st, 2nd, or drive but takes off fine from OD sanawa Transmission - Rearend 0 01-24-2012 02:36 PM
350 turbo trans takes off in 2nd stanjr41 Transmission - Rearend 2 01-23-2012 02:16 AM
350 Turbo Transmission downshifting from 3rd to 2nd on its own Jerry Blocl Transmission - Rearend 1 08-14-2010 07:20 AM
Turbo 350 skipping 2nd gear matty_torana1978 Transmission - Rearend 0 10-24-2007 05:31 AM
