350 turbo tranny / first gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2007, 06:02 PM
badriand's Avatar
The other day i put it in first easing out the driveway and noticed that it would not stay in first just pops right back to second. I crawled under the truck and unhooked the column from the shaft and manually pushed it into 1st and the same thing you have to hold it or it pops back into second. Any ideas it is a auto tranny. Thanks guys Guess i should add it runs fine in drive, just if you shift the column all the way down to first it pops backup into 2nd you have to hold the column down to keep it in first.
Old 10-11-2007, 10:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
drop the pan . look at the linkage. I've seen the spring arm that rides on the rooster comb of the shift linkage bent in such a way that it moves the shift linkage into the wrong position
Old 10-11-2007, 11:15 PM
DHMag's Avatar
if you have full length headers, they will touch the linkage when load applied and pop it into 2.
Old 10-12-2007, 09:42 AM
badriand's Avatar
Yikes, i replaced the pan gasket about 4 months ago. Basically i have been building on this truck and it doesn't go anywhere i have drove it around my block twice in the past 4-5 months (no doors, no hood, no windows etc) sitting on a stool. Basically it was working fine and i haven't done any channel to the frame , i did however drop the vehicle but that was the actual height of the truck the position of the shift linkage was left untouched. Could someting happen internally to the tranny when it is barly driven. Thanks guys for your help.
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 01:40 AM
350 turbo tranny not shifting to 3rd actionphilson Transmission - Rearend 1 11-17-2005 07:22 PM
Shifter Turbo 350 tranny Pcr21688 Transmission - Rearend 0 07-14-2005 09:50 PM
NOVA: Powerglide or Turbo 350? chevy71nova Transmission - Rearend 1 10-13-2003 05:50 PM
turbo 350 Kelgar50 Transmission - Rearend 2 05-31-2003 07:03 AM
