Originally Posted by badriand
The other day i put it in first easing out the driveway and noticed that it would not stay in first just pops right back to second. I crawled under the truck and unhooked the column from the shaft and manually pushed it into 1st and the same thing you have to hold it or it pops back into second. Any ideas it is a auto tranny. Thanks guys Guess i should add it runs fine in drive, just if you shift the column all the way down to first it pops backup into 2nd you have to hold the column down to keep it in first.
drop the pan . look at the linkage. I've seen the spring arm that rides on the rooster comb of the shift linkage bent in such a way that it moves the shift linkage into the wrong position
