350 turbo tranny leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2010, 02:25 PM
350 turbo started leaking rapidly so i changed the seal still leaks so i changed it again still leaks so i changed the seal and torque converter and it still leaks any ideals its a very rapid leak coming from the seal?
Old 11-23-2010, 02:47 PM
bowtie76's Avatar
So I am taking it you replaced the seal once or 3 times or just once? It could still be a multiple of things. If the seal is not installed properly it will still leak. It is possible that the housing maybe bad around it or the shaft itself is worn out. I would say more on the seal not being installed properly over anything else. I havent had that issue yet. I just have a leak on the cooloer line again on my tranny.
Old 11-23-2010, 03:12 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
So you changed the seal three times and the converter once ? You didn't happen to take a look at the front pump housing did you. Or the breather hole around where the seal goes is blocked if it's blocked you can't keep a seal in it.JMO
Cole
Old 11-23-2010, 06:44 PM
yes weve changed the torque converter 1 time and changed the seal 3 times and im getting tired of dropping this tranny lol
Old 11-23-2010, 06:55 PM
eloc431962's Avatar
Wiki Edits: 37
I don't blame you i would be too. And you are sure the seal is the correct one and going in properly ? If so then IMHO it's got to be either the front pump housing is cracked or the breather hole in the front i was talking about in my other post i know for a fact if that hole gets blocked it will keep blowing the front seal. I will be honest if you have already had it out that many times maybe it's time to let a pro get a hold of it before you get really .JMO But if you do decide to attempt again check around the front pump housing for cracks and make sure the breather hole is not blocked.
Maybe Crosley will see this and can shed more light on it for you.
Cole
Old 11-23-2010, 06:58 PM
tnsmith10's Avatar
when will it rain???
did you by chance check the pump bushing? is it in the right place? have you verified that its truly the converter seal, and not maybe a pump gasket and o'ring?
does it leak whether its running or not??? what were the conditions when the leak started?
high mileage on trans? what year, and make vehicle is this trans in?
Old 11-23-2010, 07:02 PM
eloc431962's Avatar
Wiki Edits: 37
x2 I was just going to post back and add about the gasket also.
Cole
Old 11-23-2010, 08:21 PM
its a turbo 350 out of 71 chevy 3/4 ton uhh maybe 50,000 on the tranny rebuit with the same issue 10 years ago only now i cant recall what was wrong and it only leaks when running i have tooken a flashlight and watched it while it was running come from the seal and i will check to see if the breather is blocked tomorow when i drop it AGAIN lol
Old 11-24-2010, 07:25 PM
ok i checked the seal breather its not clogged by what i can tell and then i started it and it was leaking worse
Old 11-24-2010, 07:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
clogged breather will typically push fluid up the filler tube before the converter seal leaks.
If the leak viewed is from the converter hub area.....this goes back to pump bushing into the seal or a crack in the converter hub as mentioned.
Quantity? of tranny fluid for 350 turbo? 40forddgc Transmission - Rearend 6 06-19-2010 09:45 AM
350 Turbo tranny Questions cheyvman_1500 Transmission - Rearend 3 06-03-2010 04:57 PM
Can I put a turbo 350 in place of 700r4? eric32 Transmission - Rearend 7 08-23-2008 02:51 AM
Turbo 350 is it too late? donvito Transmission - Rearend 1 07-04-2008 08:15 PM
turbo 350 leak, front seal area 72chevelle Transmission - Rearend 5 06-03-2004 07:32 PM
