350 Turbo tranny Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 02:54 PM
Hey all, I'm new to rebuilding world and i have recently taken on my first project of rebuilding a 4x4 85 chevy half ton. it has the 305 engine with 700r4 tranny with 3.08 gears right now, i was planning on putting in a 355 engine with 350 turbo tranny and keeping the gears. is this a good setup for power and mileage? id like to keep it a daily driver with some ponies. ALSO, im looking at a used 350 turbo tranny for $400, will a 1200 rpm stall conveter work? it has a b&m shift kit as well. im not sure on tranny specs and do's and donts. any help is greatly appreciated!
Old 06-02-2010, 03:16 PM
I had an '83 Silverado 4X4 1/2ton, 355/Turbo350, NP208, and 3.08's. It was lifted 4in. and had 33's. The gear/tire match was bad, and I ended up averaging 10mpg. Don't expect much in the mileage-department...that truck is square and pushes a lot of wind...and it's not exactly a lightweight either. Good luck on your venture.
Old 06-03-2010, 02:44 PM
well my friend said his 355/turbo350 with 3.08 gears with 33's pgets like 17-18 mpg on highway. anyone else with advice? whats a powerful gear/tire/engine/tranny combo?
Old 06-03-2010, 03:57 PM
T-bucket23's Avatar
Wiki Edits: 26
If you are looking for mileage an overdrive transmission will be better the the TH350. If the 700r4 is healthy you may want to stick with it
Chet
turbo 350 and turbo 350c riley81GMC Transmission - Rearend 6 12-12-2009 08:07 PM
Newer 96 350 Block fitting to a old Turbo 350? Chevytruck Engine 5 10-07-2008 12:47 AM
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 09:56 PM
Turbo 350 questions slickstick56 Transmission - Rearend 3 03-14-2006 12:15 PM
turbo 350 and Olds t-350 questions flatheadfever Transmission - Rearend 3 02-12-2006 08:41 PM
