350 turbo trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2010, 10:23 AM
350 turbo trans
I just rebuilt my 350 turbo trans I put new seals and clutches in it and a bnm shift kit in it my problem is i dont have 3rd gear and also reverse will pull but not good I have a strong 1st and 2nd gear thow.
Old 01-28-2010, 10:49 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
shifts are controlled by governor pressure, the governor is a centrifugal device that opens a spool valve based on speed. the modulator & throttle valve are used to supplement the governor by sensing engine load and throttle angle. this is what makes the trans shift later, or down shift when you floor it. If you are getting normal 1-2 shifts but no 2-3 shift, you may have a sticking governor or a maladjusted manual valve, (shifter cable). There's a cover on the side of the trans you take off to remove the governor, As you lift the weights on the gov. the spool valve should move freely through its entire travel & return when you let it go, If it's sticking try cleaning it with brake cleaner.
Good luck,
Rich
Old 01-28-2010, 01:28 PM
SSedan64's Avatar
Some Info here on No 2-3 shift & No Reverse>> http://th350.netfirms.com/pages/7a2-05.jpg
Old 01-28-2010, 06:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Since you have 3rd gear and reverse problems, the problem would be there , not the governor.
Reverse will work better with a weak 3rd gear because pressure is boosted in reverse....
Filling a new turbo 350 bentwings Transmission - Rearend 2 09-29-2007 10:26 PM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 10:17 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 12:14 PM
Turbo 350 to a '94 700R4 or 4L60 classic_chevy_guy Transmission - Rearend 9 01-27-2004 10:32 PM
Turbo 350 Trans in '63 Chev p/u Freedo Transmission - Rearend 1 09-04-2001 08:59 AM
