350 turbo trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2010, 08:11 PM
350 turbo trans
I just replace my tork converter and flex plate put 2qts in converter put all back together filled with fluid and it seems to take a lng time going into both drive and reverse like it's slipping then it will catch.Can some one tell me what i have done.It does it both cold and hot it did not do this before i changed these two parts.
Old 12-11-2010, 08:22 PM
396chevelle's Avatar
When you filled it did you get it up to operating temp and check the fluid level? Also while its running I would run it through each gear hesitating for a min. Just to make sure it flows everywhere its supposed to then check the level again.
Old 12-11-2010, 08:26 PM
muddi1's Avatar
Hi BigB and 396,
Thats what I suggested in his first post for this, same thing happened to my sons car. I didn't realize how many quarts/gallons it took, 11 qts total with a tranny flush and new converter.
Old 12-11-2010, 09:00 PM
Originally Posted by muddi1
Hi BigB and 396,
Yep, I did the same thing when I changed my valve body I didn't pay attention to how much drained out. I was off by 3 Quarts with the same symptoms. I'm sure thats all it is. Also when I first filled it my dipstick was at the full mark until I ran it for a bit then when I checked it. It didn't even show on the stick.
Old 12-12-2010, 06:19 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I alway's run mine through the gears several times and let it warm up,
And re-check the fluid till it's full.
Cole
Old 12-12-2010, 05:12 PM
Th 350 trans
Thanks for all the replys.I did what all yall told me to do and its still doing the same thing could the pump be bad?.I put a new mod on it made sure had good vac and new filter and brought up to full on stick shifting back and forth threw all gears till it showed full i dont no what else to do im not a trans man.
Old 12-12-2010, 07:15 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
How was the trans and converter bolted back up to the engine?
Converter bolted to the flexplate first, then trans moved up to engine and bolted down?
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Turbo 350 trans. BigB Red Sled Introduce Yourself 2 12-11-2010 07:36 PM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 09:17 PM
Turbo 350 to a '94 700R4 or 4L60 classic_chevy_guy Transmission - Rearend 9 01-27-2004 09:32 PM
Turbo 350 Trans in '63 Chev p/u Freedo Transmission - Rearend 1 09-04-2001 07:59 AM
