350 turbo trans - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-20-2011, 11:32 PM
350 tail shaft
all 79 camaros had the short tail shaft i got 2 of them do like he said pull the converter clean up the hub and replace the front and rear seals also replace the fluid,filter and pan gasket,i would also replace the dipstick tube and kick down cable o rings there known to leak just buy a gasket set with the seals thats the cheapest way to get all the stuff cost about 25 bucks check TSR racing.com i buy all my trans stuff there he has the best prices good luck
  #17 (permalink)
Old 02-21-2011, 08:05 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by biggus1
any ideas on why my trans don't shift properly as in previous post,are is it just time to replace trans?
i would suggest a governor check. Under the round press on cover near tail housing.
Check inner valve movement, check plastic drive gear
  #18 (permalink)
Old 02-21-2011, 01:05 PM
350 turbo
would trans need to be out of truck to take press on cover off to do governor ck?
350 turbo trans BigB Red Sled Transmission - Rearend 6 12-12-2010 07:15 PM
turbo 350 trans roosterone Transmission - Rearend 2 10-28-2010 06:34 PM
350 turbo trans alabamamudslinger Transmission - Rearend 3 01-28-2010 05:32 PM
350 turbo trans xxxtonyrusxxx@yahoo. Engine 2 06-28-2007 12:34 PM
350 Turbo Trans greywulf Transmission - Rearend 3 03-29-2005 09:17 PM
