Hotrodders Bulletin Board
#1
350 Turbo Trans
I have a 53 Chevy pick-up and I'm looking at a 350 turbo trans for it.I just found out that there were two different 350 transmissions,a short tail and a long tail,a difference of 3".Will a short tail trans work on my truck or should it be a long tail transmission???If I use a short tail transmission do I need a hanger bearing????The motor I'm using is a chevy 350 and the rearend is a 80 camaro 10 bolt posi.
#3
re: 350 Turbo Trans
there are 3 different lengths of t-350 in 2wd .
6 inch , 9 inch and the 12 inch tail hosuing. the 12 inch is not too common. I'd put a tail measure on the tail housing just to double check Quote:
======== Be kind to your children... some day they may be decide what nursing home to put you in |
#4
re: 350 Turbo Trans
I have a long tail shaft in my little Nova. The guy that rebuilt it said don't know how it got in my car but theres no reason it should work any different actually he preferred the long tail, less drive shaft = stronger and better balance!
Back to top |
Similar Threads for: "350 Turbo Trans"
| 350 turbo to 400 turbo swap in lemans?? | mtmniles | Transmission - Rearend | 8 | 01-24-2006 12:40 AM |
| 350 4x4 trans to 700R4 2x4 trans swap??? | punk1c5040 | Transmission - Rearend | 1 | 02-01-2004 11:14 AM |
| Turbo 350 to a '94 700R4 or 4L60 | classic_chevy_guy | Transmission - Rearend | 9 | 01-27-2004 09:32 PM |
| Turbo 350 linkage adjustment | dpj450 | Transmission - Rearend | 1 | 10-24-2001 06:35 PM |
| Turbo 350 Trans in '63 Chev p/u | Freedo | Transmission - Rearend | 1 | 09-04-2001 07:59 AM |
