350 turbo trans gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2012, 10:10 AM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
I'm replacing trans pan gasket and some mechanics say use gasket sealer and AAMCO say don't use any sealer. What do you guys recommend
Old 05-11-2012, 02:26 PM
DoubleVision's Avatar
I've never used any sealer on the pan gasket.
Old 05-11-2012, 05:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have had pan gaskets that had taken a set after being folded up in a box. On those, I use weatherstrip cement to glue the gasket to the pan and nothing between the gasket and trans body. When the pan is removed the next time the gasket will come off (at least mostly) w/the pan.
You can use finger tight studs in the corners and maybe a few other places to help hold the gasket in position if you don't want to use cement to hold it in place. Remove the studs after you get enough screws started. Or just use studs, period.
Old 05-13-2012, 07:21 PM
chevynut1's Avatar
I've never used sealer on trans gaskets. Have had good luck using Vaseline to hold gasket in place until pan bolts are in. Don't over tighten bolts.
Old 05-13-2012, 07:24 PM
Bobs36ford's Avatar
350 trans
Thanks for the advice. I tightened bolts to 20 lbs.
turbo 350 trans roosterone Transmission - Rearend 2 10-28-2010 06:34 PM
350 turbo trans alabamamudslinger Transmission - Rearend 3 01-28-2010 05:32 PM
350 turbo trans xxxtonyrusxxx@yahoo. Engine 2 06-28-2007 12:34 PM
Turbo 350 Trans bigrevkevo Transmission - Rearend 3 03-29-2007 11:33 PM
turbo 350 trans ? ben81cutlass Transmission - Rearend 3 02-22-2007 08:36 AM
