350 turbo trans issues
trans shifts great from 1st to 2nd,driving normal it doesnt feel like it goes into 3rd,when i let off it almost feels like its in nutral but if i give it gas it goes, just still in 2nd. first time i got on it, when i went to 3rd, it shifted but rpms almost stayed the same,like i was blowing though the converter. added a little fuild and took it back out the next day and it seemed fine, but still has the low rpm 2 nd to 3rd problem . this is a 500 hp big block with 4000 stall. any ideas what to check?
Some diagnosis Info here:
No 2-3 shift: http://th350.netfirms.com/pages/7a2-05.jpg Slips 2-3 shift: http://th350.netfirms.com/pages/7a2-07.jpg Pressure Test & Port location Info: http://th350.netfirms.com/pages/7a2-02.jpg |
thanks i will check those out.
do you have a strong reverse? the direct drum is used to turn reverse also if you have good reverse that kinda rules out a hydraulic apply problem in the drum. I would first check your vacumm to the modualtor. also check the governor and also check your kickdown cable adjustment as matter fact disconnect it and see if it make a difference. the cable is not needed to operate the trans as it doesnt control line pressure like on the 700s if the cable makes a diffeence then reinstall and adjust it.
I dont think there is a kickdown cable on it, reverse seems ok, but i will check it again, i will check those things, from what i read, if it was modulator wouldnt that affect 1 - 2 shift, its great and will shift anytime i want it to.
| 350 Turbo Issues! | jvest | Transmission - Rearend | 17 | 10-06-2009 09:35 PM |
| Turbo 350 Trans Shift/Slip issues | CincyMuscle | Transmission - Rearend | 5 | 09-30-2009 07:17 PM |
| 350 turbo shift issues. | Heavychevy82 | Transmission - Rearend | 4 | 09-28-2009 08:58 PM |
| Turbo 350 issues tonight.... | black66 | Transmission - Rearend | 0 | 05-03-2006 11:12 PM |
| turbo 350 issues | D. Robbins | Introduce Yourself | 2 | 11-14-2004 09:16 AM |
