350 turbo vent tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2004, 03:21 PM
350 turbo vent tube
I took my 350 turbo equipped 7 sec. drag nova to the track 9-3-04 I have not raced it for 12 weeks. On the third pass, the car lost trans fluid and traction, and they had to clean the track. The only thing I can see under the car is a hole in the top on the driver side of the 350 turbo, the hole is clean and the unit runs and shifts. My parts manager thinks that a mud dopper clogged the vent tube and when it blew ...out came to pressure and fluid. Is that even possible?
Old 09-05-2004, 05:53 PM
stu stu is offline
not really
Excess temperature or overfilled more than likely.
Do you have an external cooler?
You should have.
Old 09-05-2004, 06:49 PM
BOBCRMAN@aol.com's Avatar
I encounter the mud dauber problem all the time. One of the first thing I have to do on a stored car around here is get them out of trans vents and door, hood and trunk edges.. I also learned long ago to keep air cleaners with elements on the carbs..
