350 turbo vs 2 speed powerglide - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2006, 11:07 AM
dboyett38666's Avatar
I have a question I have a 2 speed power-glide,and a 350 turbo.The engine is a 412 cubic inch small block Chevy in a 77 camaro with 4:10 gear ratio.Which would work better the 350 or the power-glide?The car will be a street strip car. Thanks for looking
Old 05-14-2006, 11:43 AM
Depends ...
High gear ( final ) is the same 1 to 1 ...
PG is 1.78 in first ... then 1 to 1
Turbo 350 is 2.52 first ... then ... 1.52 then ... 1 to 1
The Turbo 350 will have more gear ratio in first ... but sometimes the PG works better ... less tire spin ... with the 1.78 gear
Old 05-14-2006, 11:58 AM
Crosley's Avatar
Wiki Edits: 1659
What Deuce ment to post is : the PG has 2 first gear ratios from the GM factory .
1.82 & 1.76
The 1.76 gear ratio is stronger of the 2 the PG was built with
Old 05-14-2006, 12:26 PM
1.82 & 1.76
Had actually forgotten about the 1.82 ... as it is fairly uncommon ...
I have found the 1.76 to be a LOT more common ... and I (for one ) do not believe the .06 difference in the gear ratios can be told in a street/strip car.
Old 05-14-2006, 03:47 PM
Thanks so i would probably be better of with the 350 turbo
Old 05-14-2006, 04:28 PM
A PG takes less horsepower to turn ... so it is better in some ways ...
A Turbo 350 has a lower first gear ... so that can be a plus ...
Turbo 350 ... 2.52 X 4.10 rear axle= 10.332
Power Glide ... 1.78 X 4.10 rear axle = 7.298 ... so you would have to run a 5.80 gear in the rear with a PG to have the same overall first gear as a Turbo 350 with a 4.10
You be the JUDGE !!
Old 05-14-2006, 07:50 PM
Crosley's Avatar
Wiki Edits: 1659
the 1.82 carrier is a stamped steel unit, quite weak when compared to the 1.76.
Drive pinion gear on the direct drum is small in size.
1.76 carrier is much stronger
Old 05-14-2006, 11:54 PM
Why is a Powerglide often referred to as a two-speed Powerglide yet the TH350 is not referred to as a three-speed TH350 or the 700R4 isn't referred to as a four-speed 700R4? Is 2-speed Powerglide a product of the Department of Redundancy Department? Is there a Powerglide with more or less than two speeds?
Old 05-15-2006, 06:33 AM
stepside454's Avatar
onova...its the same as when people say ..." Ihave a chevy small block 400"
If its a street/strip car,Id use a T-350. P-glides are great, but for performance applications are usually better suited for lightweight/deep geared cars.
Old 05-16-2006, 12:59 AM
Rocket455's Avatar
I lay strips in neutral.
onova, wasnt there a unique 3-speed powerglide used in early corvettes? believe around '56.
Old 05-16-2006, 07:31 PM
Crosley's Avatar
Wiki Edits: 1659
no. glides have been 2 speeds. 1956 would have been a cast iron glide.
this could come from the fact that GM sold a big block motor labeled a '400 cid' motor when it actually was a 402 cid engine. I've seen a few '400' big blocks in early 70's chevy trucks
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 09:56 PM
SBC 350 and Turbo 350 OR 2 spd Powerglide??? boneyard Buick Engine 5 04-04-2006 12:34 PM
turbo 350 and Olds t-350 questions flatheadfever Transmission - Rearend 3 02-12-2006 08:41 PM
turbo 350 350 blazer Transmission - Rearend 3 01-30-2003 09:33 AM
