350 turbo vs 200R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2009, 03:42 PM
350 turbo vs 200R4
Our little S-10 is running a V-8 conversion.
350ci.300h.p. sbc with a 350 turbo and a 373 geared rear. The trans is good,but we have been thinking about installing a 200R4 or a 700R overdrive trans. Just wondering how much if any will it make in performance. Like taking off. I read were it would give it a lower first gear and a much higher high/overdrive gear. So in overdrive cruising will be a lot less rpm. But will there be a lot of difference and noticeable in low gear. And would the 200R4 or 700R be better ? Thanks !
Old 11-03-2009, 04:01 PM
Ck out gear spacing first gear in a 700r4 3.06 ,2004r 2.74 first gear second is closer on 2004r and it is same length as most 350.
Old 11-04-2009, 11:12 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
200R4 OD is .67 and 700R4 OD is .7. Here is a link that has some info on the different transmissions. Has gear ratios and measurements. http://www.rowand.net/Shop/Tech/Auto...issionSwap.htm
350 Turbo Locking up in L1 chrispc88 Transmission - Rearend 4 07-23-2009 12:33 PM
SBC 350 and Turbo 350 OR 2 spd Powerglide??? boneyard Buick Engine 5 04-04-2006 12:34 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350 or 200R4? Forsaken502 Transmission - Rearend 14 12-09-2003 10:11 PM
Turbo 350 1980 Malibu Transmission - Rearend 14 07-27-2003 04:24 PM
