350 turbo vs 400 turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2009, 03:57 PM
I have a 1971 nova with a 350 bored and built to a 355 with a 350 turbo tranny and a set of 355 Richmond gears in the rearend. The car runs very well but i was curious if a 400 turbo would add a little more pep to the launch. Is the ratio between the two significant enough to speed the car up upon take off or is it a waste of time and money. im also aware of the 2.75 low gear 400's but am concerned that the transition between first and second would cause a loss in acceleration.
Old 04-22-2009, 04:06 PM
ericnova72's Avatar
More for Less Racer
Turbo 350 has a 2.52 low gear, the Turbo 400 is 2.48 low gear. It's not enough to even be noticable.
Old 04-22-2009, 04:15 PM
fast68's Avatar
likes chevy trucks & boobies
also keep in mind more power is needed to run a 400 than a 350, or that is what is always claimed anyways. good luck
Old 04-23-2009, 04:57 AM
Th-350 is lighter than the 400. Weight equals power but the th-400 is much more durable.
Choose Pontiac 400 or 455? & Turbo Questions TheMonkey Engine 33 08-11-2009 11:01 PM
my turbo 400 won't shift!! skylark65 Transmission - Rearend 2 07-01-2007 07:58 PM
65 skylark turbo 400 trans. install question skylark65 Transmission - Rearend 7 05-09-2007 09:29 PM
350 turbo vs 400 dboyett38666 Transmission - Rearend 5 03-07-2006 09:26 PM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 07:48 AM
