-   -   350 turbo vs 700r4 (http://www.hotrodders.com/forum/350-turbo-vs-700r4-226219.html)
chevota'54 11-18-2012 02:06 AM
350 turbo vs 700r4
blowed the 2nd & drive sprags out of my 350 tranny tonight. have a 700r in stock, if I remember right I'm gonna have to shorten my drive shaft, right?:confused:
gearheadslife 11-18-2012 06:23 AM
yup and the correct t.v cable brackets, move cossmember
chevota'54 11-18-2012 09:55 AM
Yup, thats what I thought. Thanks gearheadslife, its in my '54 3100. Messin around with the Holleys front squiters, was idleing a little high when I went backed out of the garage for test run, stopped to adjust the idle and air-fuel,still about 950 RPM, put it in drive and bang! still had rev. and 1st, limped back home. See Y-all at the Turky Run in Daytona
Energi2DMax 11-18-2012 09:59 AM
If its a stock 700r4 then you might just blow it up too...unless you do some extensive upgrades to the 700 there prone to failure anything over 300hp.. so I been told
123pugsy 11-18-2012 10:27 AM
If the 350 has a nine inch extension housing there will be no cutting of driveshafts.
chevota'54 11-19-2012 09:01 AM
If the teeth are stripped off of the governor would that cause it not to pull in 2nd and 3rd?
chevota'54 11-19-2012 11:22 PM
governor was fine, installed the 700r4, now where to go to shorten the driveshaft, hum, got a Astro out back. Damn, it fits. See Y-all at the Turkey Run in Daytona.
chevota'54 11-19-2012 11:25 PM
Oh Yea, the 700r4 I have was built for 500HP plus. Have a nice day.
123pugsy 11-20-2012 03:33 AM
Maybe I ought to meet you at the run.
I could get you to rub off a bit of your luck on me.
Glad to hear you got it sorted out.
