350 turbo vs 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2012, 02:06 AM
chevota'54's Avatar
Poor Boy's Toys
350 turbo vs 700r4
blowed the 2nd & drive sprags out of my 350 tranny tonight. have a 700r in stock, if I remember right I'm gonna have to shorten my drive shaft, right?
Old 11-18-2012, 06:23 AM
gearheadslife's Avatar
MentalMuffinMan
yup and the correct t.v cable brackets, move cossmember
Old 11-18-2012, 09:55 AM
chevota'54's Avatar
Poor Boy's Toys
Yup, thats what I thought. Thanks gearheadslife, its in my '54 3100. Messin around with the Holleys front squiters, was idleing a little high when I went backed out of the garage for test run, stopped to adjust the idle and air-fuel,still about 950 RPM, put it in drive and bang! still had rev. and 1st, limped back home. See Y-all at the Turky Run in Daytona
Old 11-18-2012, 09:59 AM
Energi2DMax's Avatar
If its a stock 700r4 then you might just blow it up too...unless you do some extensive upgrades to the 700 there prone to failure anything over 300hp.. so I been told
Old 11-18-2012, 10:27 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
If the 350 has a nine inch extension housing there will be no cutting of driveshafts.
Old 11-19-2012, 09:01 AM
chevota'54's Avatar
Poor Boy's Toys
If the teeth are stripped off of the governor would that cause it not to pull in 2nd and 3rd?
Old 11-19-2012, 11:22 PM
chevota'54's Avatar
Poor Boy's Toys
governor was fine, installed the 700r4, now where to go to shorten the driveshaft, hum, got a Astro out back. Damn, it fits. See Y-all at the Turkey Run in Daytona.
Old 11-19-2012, 11:25 PM
chevota'54's Avatar
Poor Boy's Toys
Oh Yea, the 700r4 I have was built for 500HP plus. Have a nice day.
Old 11-20-2012, 03:33 AM
123pugsy's Avatar
Wiki Edits: 29
Maybe I ought to meet you at the run.
I could get you to rub off a bit of your luck on me.
Glad to hear you got it sorted out.
350 turbo vs 700R4 Chevyjeepster Transmission - Rearend 5 11-22-2011 01:47 PM
TURBO 350 or 700R4 Chevy_man08 Transmission - Rearend 1 06-24-2008 06:45 AM
350 Turbo to 700R4 jdshort98 Transmission - Rearend 7 05-07-2008 10:52 PM
700r4 to 350 turbo. 68novafan Transmission - Rearend 14 03-26-2005 06:52 PM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
