350 two bolt build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-09-2012, 07:29 PM
E.T. divided by $ spent= Speed
Unless its gonna be a monster race motor I'd be less concerned with it being a 2 bolt block,as I would it being a high nickel block. Look under the timing cover for a cast 010 number that indicates 10% higher nickel block.These were generally the older driver side dipstick block with the wide water pump boss tab on the pass. side.
Your better off with a 2 bolt 010 block than a 4 bolt thin block.
  #17 (permalink)
Old 08-09-2012, 08:54 PM
350 2 bolt main
If you want to build a 383 stroker you can purchased Program 4 bolt main caps. The machine shop can drill the block, fit the caps and align bore the block when done. I had my 454 block decked to .005 and converted to 4 bolt main caps for $500 including align bore. Like was said the extra cubes = more bottom end torque to get that heavy truck moving. You said the budget was $3000-5000, you can have nice 450 hp 383 stroker for that price. BTW you could buy a rotating like this to save money. Eagle Street/Strip Kit, SB Chevy 400, 3.750' Eagle Crank, 6.0' Eagle Rods, 10.3:1 SRP Pistons - Eagle Street\Strip Rotating Assembly Kits - Eagle Rotating Assembly Kits - Rotating Assemblies | CNC Motorsports | Car Parts | Truck Parts | Competition E. Purchase a set of Dart SHP top end kit to save some more $$$: Dart 01311132 Dart SHP Top End Kits for SB-Chevy
Newer Center Bolt 350 build dsgb610 Engine 25 02-10-2011 08:49 PM
383 build question (new 4 bolt or machine my 2 bolt) chucksrt Hotrodding Basics 18 12-20-2010 11:17 PM
Build a 10 bolt or 12 bolt for 450 HP ?? Blownchevelle68 Transmission - Rearend 7 05-11-2010 08:34 PM
2 bolt 400 or 4 bolt 350 chevy chevy350cutlass Engine 19 10-30-2008 08:42 AM
2 bolt vs 4 bolt main 350 small block CanadianCory Engine 9 10-30-2005 09:31 PM
