I've been there.... and I didn't mean to sound so apocalyptic in my last post.
I put $4000 into a Caddy 500 build only to be disappointed with my choices and I ended up selling it for $500. So far I've put $19k into a 66 Bonneville and its just now coming out of the body shop. I have another $10k to go at least. But that is why this forum was invented ![]() I think you have a great engine, but the heads are holding you back. Spend a little money up top on heads and you'll be very happy. |
Youch, i know the feeling -- the money never comes back. That '66 will be worth it eventually. Thanks on the heads vote, that was my sense that it's a good build candidate for a lobotomy!! At least the motor won' t have to come out again. ... I'm losing hair, patience and knuckles. But at least I'm not alone!!!
With a 350cid, stock stall, and 3.08 gear. The engine should be limited to around 350hp.
A 400-450hp 350cid would need around a 3000-3500 rpm stall and a 3.73-4.11 gear A 450-500hp 350 will need a 3500-4000 stall and a 4.11-4.56 gear. Needless to say, big cams, high rpms stalls, and high numeric gears will not make a nice street car. and not good for durability or mpg. A 3.08 gear with a stock stall makes a nice driver but needs low rpm torque to go fast. keep the cam mild, add more cids, good heads, free flowing exhaust, dual plane intake, and a good carb. In this case, change the heads, add 2-1/2 exhaust, use a dual plane intake, get a holley 3310 carb. And consider a little 150hp shot of NO2 to make the 500hp goal. N02 also increases torque about the same as the hp increase. Also, your current ignition timing is not high enough. Try 17 or 18 degrees at idle, and use the vacuum advance in the manifold source (vacuum at idle). Get an adjustable vacuum advance canister (summit racing) and add 10 more from the vacuum advance. so the engine should be idling at 17 + 10 =27 degrees. This set up will help the engine's throttle response. Hotrodding is a way of life. If you start to add up money then it isn't fun anymore. However, there are cheaper ways of getting the same results which takes time to figure out. |
A Holley Street Dominator can be a good manifold. Depending on which one you have. There was one that was basically a knock-off of the LT-1 high rise dual plane. That's p/n 300-36. There was another one, p/n 300-38 (both were previously sold under the name "Contender") that was basically just an aluminum low rise Q-jet manifold. If you've got the high rise manifold it will have a square bore carb flange. If you've got the low rise Q-jet copy it will have a spread bore flange. Which could also cause you problems. An Edelbrock carb has both bolt patterns, so it will bolt on. But there could be interference with the linkage or the butterflies that will keep the carb from doing everything you want a carb to do for you. You should check to see which manifold you have, definitely. Unfortunately the part numbers are stamped under the manifold. You should be able to determine which manifold you have by the flange. You may very well have the low rise manifold because that's what the original L46 had to prevent hood interference issues. But then, it also had a 750cfm Rochester Q-jet, and you have a 600cfm Edelbrock. So, you have a bit less cam than an L46, and less carb (which may not be working optimally as it's best not to mix square bore carbs with spreadbore manifolds & vice versa). You undoubtedly have less compression as well; did your mechanic build you an 11:1 small block? That's how the L46 was built. You basically have less of just about everything that matters when it comes to making power that the factory had to put into them back when Chevy was optimistically rating them at 350 horses. That may go for the heads as well, depending on what your engine builder did to them when he reworked them. Frankly, I don't see how he could have possibly believed you'd get anywhere close to 400 horses when he was building you what's essentially a lower-performance version of the L46. |
VERY helpful. I think i have the square bore open manifold. It seems to be higher than a stock Qjet manifold. Is this good? I wasn't certain from what you said. I suppose I could check for butterflies interfering, seeing if they don't open completely, i presume. Yikes. That would suck. I think he zero-decked it and did something special with the heads guy he works with and ordered appropriate pistons for the setup, with standard compression ratios for pump gas. That's all I remember. The receipt and parts list looks like Chinese to me in some parts (just cause I can't figure some of it out). The pistons look like forged L-2256 .30 over. Sounds like I need new heads but need to know if the manifold is interfering. Any recommendations on heads? My old ones are 2.02s with guide plates, ARP studs and those mentioned rollers. ... thanks a lot for advice. |
http://www.crankshaftcoalition.com/wiki/Intake_manifold It looks like these are your pistons. http://www.summitracing.com/parts/SLP-L2256F30/ They should give you about 9.5:1 compression with the 64cc combustion chamber (that is what your heads will have if they are off an L46 vette) and a .039 gasket. Basically, what your engine builder put together sounds more like the L82. It was rated at 250hp net when it came out in 1973. So I don't think its underperforming for the build. It just underperforms compared to what your builder told you it would produce in terms of horsepower numbers. I don't really care to recommend heads; I like AFR though. Just about any aftermarket head will breath better and has a better combustion chamber than the heads you currently have. |
When you say you're using some later year 2.02 heads, you may well have open chamber 76cc heads. The closed chambered heads were only used for a few more years after that '69 vette came out although Chevy did sell versions of them as service replacement parts. The close chamber heads aren't any great shakes by today standards. These open chamber heads were worse, and aren't performance heads by any stretch of the imagination even if Chevy shoved some big valves into them. I think just about any good aftermarket aluminum head would make a night and day difference on that engine. Just don't go crazy and get something with huge ports. Something with 180cc intake ports would work well and definitely nothing bigger than 200. |
| 350 build | MalibuMike | Engine | 16 | 03-07-2012 02:16 PM |
| 350 Motor 350/400 HP build | smokeb1 | Engine | 6 | 01-18-2012 11:18 AM |
| 350 build questions, looking for 300-350 hp | Jaiden2010 | Engine | 18 | 06-23-2011 07:49 AM |
| 350 build up | 66pontiac | Engine | 2 | 12-05-2003 05:30 PM |
| 350 Build Up | diognes56 | Engine | 3 | 11-19-2002 09:00 PM |
