350 with a vacuum leak, yet leaning carb improves idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 08:53 PM
Hey everybody, as you can tell from the title of the post, I have a chevy 350 that has a vacuum leak around the number 1 and 3 intake ports. I have leaned out the idle and it has greatly improved idle quality. When I started, it was at about 14in of vacuum and now after leaning it out I am running at about 16.5 in. I definitely have a vacuum leak because I was almost able to stall the engine by soaking the area around the number 1 and 3 cylinders. So simply put, what can be going on here? This is the exact opposite of what I think should happen when I lean it out further. Just so you guys know, the only reason I came across this is I noticed my mileage has dropped from 15 to about 11 and after changing plug wires (others got cooked on my headers) my idle is horrible. Any help would be greatly appreciated. Thanks in advance guys.
Old 06-15-2010, 10:11 PM
406 bug's Avatar
9.82 @ 139mph
Thats because the idle screws(assuming thats what you mean)don't lean per se, they increase or decrease a set mix of air and fuel.
Old 06-15-2010, 11:01 PM
But doesn't turning the screws clockwise on an edelbrock carb technically increase the air entering the engine? So assuming I am completely confused (which I may be, I prefer fuel injected motors lol) is it maybe just the vacuum leak causing my issue and not being to rich as well?
Old 06-15-2010, 11:20 PM
406 bug's Avatar
9.82 @ 139mph
The idle (mixture) screws on holleys do not control the idle circuit air/fuel ratio and I believe this is also true on your carb.
Old 06-15-2010, 11:30 PM
So essentially all I am doing is increasing the idle speed via the "idle mixture screws" which is covering up the issue?
Old 06-16-2010, 12:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
406 is correct that opening the air mixture screws adds the quantity of emulsified air/fuel to the carb throats. It doesn't add just air or just fuel- it adds more of both. To add more fuel, you'd need to open the idle restriction or decrease the size of the idle air bleed.
So, adding fuel/air via the idle mixture screws does, in effect, tend to mask over a vacuum leak- to some extent.
The problem lies in that while the added mixture will help the vacuum leaking cylinder(s), it will over-richen the others.
cam questions novaboy72 Engine 3 05-28-2010 02:33 AM
Setting carb on SBC by vacuum @ idle? 5_speed Hotrodding Basics 6 12-31-2008 12:17 PM
running no vacuum advance oregon chevelle Engine 28 02-07-2007 08:17 PM
Ported Vacuum 72Orange Engine 18 08-07-2006 09:56 PM
Low Idle Vacuum on 94' TBI Suburban edge Engine 4 07-21-2004 01:49 PM
