350 valve question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2013, 12:38 AM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
350 valve question
Hey guys,
I have a nasty lifter tap. I have adjusted several times. It either gets worse, or better for a small amount of time.
I would like to put new lifters and new roller rockers on.
Would this fix my problem? Or am I looking at a valve issue....
Thanks
Mike
Old 07-03-2013, 12:43 AM
techinspector1's Avatar
Wiki Edits: 326
1. Remove valve covers, observe all rockers for moving the same amount. If there is one or more rockers that don't move as much as their mates, then the cam is going flat.
2. Lay a straightedge across the top of the rocker studs to see if one or more studs are pulling out.
Old 07-03-2013, 02:46 PM
Originally Posted by dub View Post
Hey guys,
Thanks
Mike
Or a wiping out cam lobe.
Old 07-03-2013, 06:19 PM
delawarebill's Avatar
another
i had a nut go bad on one valve.. put new ones on and problems solved.. i had to keep adjusting it also and it didn't last either.
Old 07-03-2013, 07:11 PM
BOBCRMAN@aol.com's Avatar
Could be many things. remove a valve cover and look.
I once bought a short Chevy school bus at auction. It had a nasty tick/hammer noise in the engine. Got it cheap and hauled the three skids of parts I bought home with it.
Removed the valve cover and found that the 350 engine had been run with a bad rocker arm. Run so long that the valve tip was thru the rocker and the arm was actually opening the valve by pushing on the valve locks and spring retainer.. Replaced the rocker, used a file to flatten the rounded off top of the valve. Engine ran for years.
YES, I was a short busser!!!
T-350 Valve Body Bolt Question zardiw Transmission - Rearend 1 04-04-2013 03:50 PM
75' 350 : Edelbrock tall valve covers and A/C Question Calderone Engine 1 04-18-2009 06:09 PM
T-350 Valve Body Rebuild Question jnobody Transmission - Rearend 2 04-02-2009 06:05 PM
350 head question, burnt valve BadA$$37 Engine 25 12-31-2007 11:43 PM
Question: 305/350 valve guide spread Mad Maggot Engine 3 11-17-2004 01:18 AM
