350 valves ticking? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2010, 06:55 PM
mcks's Avatar
350 valves ticking?
New to the site. Tried looking at other posts and was not able to find any answers. So to start I have a fairly freshly rebuilt 350 bored .60 lunati voodoo cam with hydraulic lifters, RHS heads, comp magnum roller tip rockers. After having problems getting it tuned in (still learning all this) I took it to the shop to have it properly tuned. No ticking while I had it. Mech. tuned carb, timing, and adjusted valves. He drove it and said it was running great. Shut it off and restarted and started to tick. He adjusted one of the valves again. And it ran awesome my first two trips around town, no tick. I started it up the third time and started to tick again. He said it may be a lifter collapsing. So after a long story my question is does anyone agree with this, and is there anyway to make sure that is what it is. I appreciate any help.
Old 08-27-2010, 07:12 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Considering I don't know if the proper break-in procedure was used on the cam or if the additives were used , I can't say for sure , but it sounds like a cam lobe going flat . A dial indicator would be real nice about now to see if the noisy lifter is traveling as far as the others . On the other hand , if it's the same rocker having to be readjusted everytime , there may be enough difference to measure with a ruler .
Old 08-27-2010, 07:17 PM
bigdog7373's Avatar
Of course it's fast
Try loosening the rocker nuts all the way so you could remove the push rod but don't actually remove it. Then tighten the rockers nuts back up agian. Do this by tightening it while you spin the push rod and when you start feeling it get a little more difficult to spin, stop. Then tighten it another half turn. This lets the lifters get pumped up with oil but will still alow it to open he valves without any hanging open. Good luck
Old 09-12-2010, 11:32 AM
mcks's Avatar
Thanks for the answers. Sorry it took so long to reply. Adjusted the valves again and have had no problems since. Again thanks for the help.
Old 09-12-2010, 11:38 AM
Greg T's Avatar
www.krusinklassics.net
Keep a record of which one causes the problem. If it comes back again and the same lifter is affected, I would suspect a lobe going flat.
new block mikey1476 Engine 8 04-12-2009 09:34 PM
305 heads with 1.94 valves on a semi stock 350? robbiesmechanic Engine 3 03-20-2009 09:19 PM
Olds 350 cu in, no oil to valves kleen56 Engine 11 03-02-2009 12:25 PM
Olds 350 1971 heads - valves - HELP! bandit79jun Engine 18 12-23-2008 05:11 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
