350 vortec in 85 chevy shortbed questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2011, 09:01 PM
Jus brought a 02 chevy express van 2500!! Im looking to put that motor nd tranny in a 85 chevy shortbed!! Do I hve to do any kind of special mods to make it work? Wat about the wire harness nd things like that?????????
Old 01-14-2011, 09:11 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
[QUOTE=Seanj]Jus brought a 02 chevy express van 2500!! Im looking to put that motor nd tranny in a 85 chevy shortbed!! Do I hve to do any kind of special mods to make it work? Wat about the wire harness nd things like that?????????[/QUOTE
are you sure it has a 5.7L 350 vortec. i would be willing to bet it's a 6.0L 364cid vortec, but either way the trans should be a 4L60E. it will work but will be a pain in the butt, cause the computer and all the wiring will have to go with it. it wont be just a simple swap
not to mention that you will have to update the entire fuel system in you 85 to get enough pressure to use EFI
Old 01-14-2011, 01:48 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
not that it really matters to the question but the chevy express vehicles did carry the vortec 5.0L and 5.7L until 2002, so it is more than likely that this is a gen I sbc and not a gen III. Also, the trans will be a 4L80E if it is in fact a 5.7L 3/4 ton. If it's the 5.0L, it'll have a 4L60E.
To answer the OP, though, this swap has been done a million times and a simple search will be able to retrieve for you the info you're looking for. It would probably be easiest to swap the FI out for a carb setup and to use a 700r4 transmission. Also, the CSFI system isn't worth the trouble of keeping. Believe me, I deal with it every day.
Old 01-14-2011, 04:40 PM
thanks for the responds
Old 01-14-2011, 04:56 PM
LATECH's Avatar
dump the van, get a 502 BBC and dump in the 85.
1987 Chevy shortbed 4x4 gear ratio questions newattruckin Transmission - Rearend 6 05-09-2010 06:13 PM
Vortec heads Questions chewyscool Engine 10 08-11-2008 10:31 PM
1959 chevy apache 3100 shortbed fleetside 396marti Introduce Yourself 1 03-30-2007 08:16 AM
Dropping a '78 Chevy shortbed gpeak Suspension - Brakes - Steering 2 01-07-2004 10:23 PM
1997 350 Vortec Questions bobfray Engine 6 11-28-2003 01:15 PM
