Another name for inverted dome is D-shaped dish. I do not know if a piston w/the specs I described is even made- I'm just saying what the ideal situation would be. You may end up having to use a round dish piston.
Depending on your skills and equipment, you could enlarge the chambers some to lessen the need for a dish or have this work done. But any hand work is going to be costly if done by a qualified shop. Last edited by cobalt327; 09-14-2011 at 09:46 PM. |
When I plan on reworking the chambers, I will mark the heads left and right and keep them in that location. Then you simply place the heads on the engine w/a few bolts snugged down to hold them in place so you can flip the engine over. Reach down inside each bore to scribe a line that's the size of the bore. Keep the work you do to the chambers inside this line.
If the work is done w/some thought to unshrouding the valves, this can help the performance as well as helping the CR situation. |
Here is the information off the manufacturer website regarding the pistons. I think it is different than what the summit website states.
Mfg. Chevrolet Eng. Family Small Block Bore Dia. 4.030 Compression Distance 1.548 Weight (Grams) 545 Dome Volume -6.88 Head Shape Flat; 4 reliefs Top Ring 5/64 2nd Ring 5/64 Oil Ring 3/16 Pin Style p or f Bore Clearance See "Piston Fitting Information" on carton label |
I'm running a Vortec Block with a 383, 501 Lift cam and Dish piston. My CR is 9.35:1. happily runs on pump mid grade. I tightened my quench to .031. I know its close but with the dish there is zero contact.
If I were to do it again in a 350. Shoot for 9.5:1 a Silvo Lite D-Dish piston, .038 Quench. Get the block decked to .010 In the hole. buy GM gaskets at .028 (about 19 a piece from the Chevy dealer). Run a 525 ish lift roller cam with a 108-109 LSA (good and rumbly and still decent vacuum) . (and get the Heads pocketed and polished) or buy a set of e-tec Vortecs. and sell your stocker Vortecs for 250-300 on C-list. this should net you 350 -375 HP and really nice torque (if its on the street torque is king) Hence why i did a stroker) with 9.5 and a really solid quench you never worry about detonation on a crappy tank of fuel or a screwup keeping your quench solid also boosts Volumetric efficiency (sp) Tech inspector helped my with all this. So did Cobalt the guys are sharp its been 10 Yrs since I touched a SBC and I cou;dn't be happier. Dave vizard has run SBC down to .028 Quench with minor kissing at 5K+ RPMS but its not necessary. Couple things to watch out for. Use a CARTER universal fuel pump, about 85 from Fisher auto parts. (smaller than the Holleys, Mount it to the frame close to the tank with rubber behind it (its Loud) SUPER IMPORTANT Check your cam stud mine rubbed the Timing cover i had to tear it down, problem was the 1pc oil pan and the "Right Stuff" sealer I am removing the oil pan now to replace the oil pan gasket because it tore. The stud on the cam stuck out to far so CHeck Check Check. Buy the cloyes Hipo roller Chain set 65.00 well worth it and run the cam back 1 setting. (can't remember which character to line it up with I can look at mine at work today) Also any tin TC will work just check the cam stud. All told I have under 2K in the entire build. |
if your Fuel pump is half drilled ask the machinist what he would charge to finish it. mine said 125 Well worth it IMO the pump wiring and relay cost my 125 or more plus all the hassle.
The compression height should be 1.56" ideally, 1.54" is common to "rebuilder"-type pistons and these are 1.548". This will mean that you'll want to pay attention to head gasket thickness and deck height to keep the quench at or near 0.040". What are the real specs on the less expensive pistons? I believe- given your goals- the cheaper pistons will do just as good, and the money you save can go to a torque plate hone job. Or did I say this already??
One website selling the same pistons have these specs.
H345ACP30 4.030" 64cc 9.47 cr Dome Style: Flat Top 4VR Rod Length: 5.700" Compression Height: 1.548" Dome Volume: -5cc The more people I call and ask what the compression ration will be with 64cc I get a different asnwer each time. |
In any event, IMO you'll do better w/a compression height of 1.56". Quote:
| 97 Vortec block help | tmartellc | Engine | 2 | 09-05-2011 11:06 AM |
| 96 vortec 350 block? | 396chevelle | Engine | 9 | 12-29-2010 11:07 PM |
| TBI vs Vortec Block | zildjian4life218 | Engine | 11 | 01-26-2010 01:48 PM |
| vortec block???????? | slr6000 | Engine | 5 | 09-24-2003 06:19 AM |
| Vortec on old block?? | stereodud | Engine | 16 | 10-13-2002 11:24 AM |
