350 Vortec block - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 10-07-2011, 11:59 AM
1969chevyss's Avatar
Originally Posted by cobalt327
Can you say chamfered bores?
What do you mean? Does it not need to be chamfered?
  #92 (permalink)
Old 10-07-2011, 06:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
They need to be chamfered. And they sure look like they are. Sometimes photos can be deceiving, it looks like a lot is all, and before you ask- no it won't be a problem.
  #93 (permalink)
Old 10-07-2011, 06:32 PM
Mann lol you had me sweating I was getting ready to curse the machine shop out. And you took for ever to reply back, lol. I did notice that when I compared my block to my buddies which is not chamfered. Thanks for looking. I can tell now you are going to be a big help on this build.
  #94 (permalink)
Old 10-08-2011, 08:54 AM
King of my Man-cave.
The bores look like they may have a little TOO much chamfer. Make sure your head gasket does not over hang into the bore at the chamfer. If they do, you may need to use a 400 head gasket.
  #95 (permalink)
Old 10-08-2011, 10:42 AM
Thanks I will keep an eye on that when I install heads.
  #96 (permalink)
Old 10-14-2011, 02:30 PM
I have a set of Clevite 77 P series rod and main bearings. My crank is an eagle that has a .092' radius on the rod journals, main journals, rear seal and snout for supposedly increased strength. Will my rod and main bearings work or do I need a different set?
  #97 (permalink)
Old 10-14-2011, 02:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Typically an "H" bearing is used w/large crank fillets. You must check the "P" bearings to see if they crowd the fillets, and even though your .092" radius isn't huge (0.125", or 1/8", is typical in many cases), I suspect they may need to be clearanced.
  #98 (permalink)
Old 10-14-2011, 03:03 PM
Thanks for the reply, i will check and see.
  #99 (permalink)
Old 10-15-2011, 08:11 PM
Is a brand new GM nodular iron crank better than the eagle cast steel crank? Which would you use? Just asking because I found a guy who supposedly has a brand new one.
  #100 (permalink)
Old 10-16-2011, 07:10 AM
The nodular crank casting number is 14088526
  #101 (permalink)
Old 10-25-2011, 07:25 AM
I am taking my parts to the machine shop this week to get a balanced done. Here are the parts that I was told by a known good machine shop to bring in for the balance. Let me know if this sounds right.
Harmonic balancer plus bolt
Front crank timing gear plus both keys
Crankshaft
Flywheel plus bolt
Rods
Pistons
1 rod bearing
1 ring bearing
« Cat removal | Ohio »
97 Vortec block help tmartellc Engine 2 09-05-2011 11:06 AM
96 vortec 350 block? 396chevelle Engine 9 12-29-2010 11:07 PM
TBI vs Vortec Block zildjian4life218 Engine 11 01-26-2010 01:48 PM
vortec block???????? slr6000 Engine 5 09-24-2003 06:19 AM
Vortec on old block?? stereodud Engine 16 10-13-2002 11:24 AM
