Originally Posted by kraft123
Can someone tell me what needs to be changed when putting a 1988 350 motor into a 1999 chevy pu with a 350 vortec specifically the crank sensor area?
Depends on how you want to go, to convert the pick up to support all the systems and the EFI of the 99 Vortec is complicated and expensive as all the 99's systems have to be integrated into the 88. If you want to just use the 99's engine with either TBI or a carb the process is a lot simpler and cheaper.
So what does the 88 currently have for induction TBI or a carb? The transmission if automatic will be a 700R4 unless it has a heavy duty tow package in which case it might be the 3 speed TH400. A manual is also simple to swap.
Bogie
