350 vortec heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2008, 06:39 AM
350 vortec heads?
i'm rebuilding my sbc 350 and i've seen alot of talk on vortec heads , i know if i went to the vortec heads i'd have to change my intake but are the push-rods the same rockers ect... just wondering i can't afford aluminum but vortec would be in my budget. thanx for you input
Old 06-21-2008, 07:14 AM
SSedan64's Avatar
Rockers are different, self aligning type.
Old 06-21-2008, 09:45 AM
Do it right and you won't be disappointed. What are you looking to do, and what kind of budget? You get those two straight and you'll be in business.
Old 06-21-2008, 09:57 AM
buget
i.m just looking for a good running sbc if you check my treads you'll see what i'm doin ( i don't know how to drag it to this post ) all in all 300 hp but with longevity ,it's goin in my restored 71 c/10 that i pull my bike on a trailer with for vacations and such i just want to do it right the first time .
Old 06-21-2008, 10:26 AM
SSedan64's Avatar
HD You'll love the Vortecs on your truck, that's what they were designed for & used on, 96-99 trucks. Great torqy head. Get them already machined for more lift. Good Price here + thicker castings. http://www.competitionproducts.com/p....asp?dept=1262
Old 06-21-2008, 11:28 AM
techinspector1's Avatar
Wiki Edits: 326
Bore 0.030" over. Use these pistons for 9.0:1 with the Vortec heads. Use 400 wet sandpaper to smooth sharp edges on the crown and eliminate the possibility of hot spots that could contribute to detonation.
http://kb-silvolite.com/performance....tails&P_id=154
Cut block decks for 0.012" piston deck height. Use GM 10105117 head gaskets (0.028" compressed) for a squish of 0.040".
Use a cam something like this. It matches the 9.0 static compression ratio and can be used with a stock converter. The lift will be ok with stock Vortecs and based on the lobe separation angle of 112 degrees, it will make good manifold vacuum to operate power brakes. I would normally recommend a roller hydraulic, but it sounds like your funds are limited.
http://www.cranecams.com/?show=brows...tType=camshaft
Scoggin-Dickey Chevrolet offers a Vortec head kit with 12558060 heads assembled with valves and springs and includes head gaskets, head bolts, rocker arms, Edelbrock Performer intake (idle to 5,500 rpm's), intake gaskets and 12-point head bolts. Part #SD8060KIT.
http://www.sdparts.com/product/SD806...merIntake.aspx
GM HEI distributor curved for 20 degrees centrifugal advance, all in by 2,800 rpm's. Start with 12 degrees at the crank, increase to 14, then 16 as you determine results while operating the motor. Vortecs don't require as much advance as earlier chamber designs. Verify TDC at the damper ring during your build so you can time the motor with a light when done and know it's right. If in doubt about the validity of your damper, send it to one of these guys for a rebuild or purchase one of their rebuilt units.
http://members.aol.com/damperdoc/
http://www.damperdudes.net/
Stock-type oil pump. High pressure or high volume will not be necessary (or desirable) on this build. Use a modified distributor housing or a purpose-specific tool to prime the system before initial startup.
http://paceperformance.com/index.asp...D&ProdID=25140
Put 6 quarts of good quality oil in the pan and add 10 ounces of this to the oil. It has the ZDDP in it which has been eliminated from motor oils.
http://www.sfrcorp.com/product/9
600 cfm Edelbrock/AFB or 750 Quadrajet. The Quadrajet will give the best mileage and probably the best power also.
Good quality headers, 1 5/8" primary tube size with max 2 1/4" pipes and an "X" or "H" crossover before the mufflers and pipes all the way to the rear to prevent droning inside the cab.
That's how I would do it. Good power and the ability to operate on junk pump gas without detonation. Other board members may have alternate suggestions for you.
Old 06-21-2008, 11:38 AM
boatbob2
vortec heads......
HI,i have a cross ram on a sbc,using 2 --500 cfm edelbrock carbs. if,i change to vortec heads,can this manifold be redrilled to match the new heads??
Old 06-21-2008, 11:55 AM
Wiki Edits: 326
I've never done this, so have no direct experience with it, but have read that there are some sealing problems.
SBC 305 Heads on a 350 ???? Brawler Engine 8 01-06-2009 09:48 PM
chevy 350 vortec heads ....wat cam?? 47chevrolet Engine 9 09-04-2007 03:12 PM
Motorheads...Need help with Vortec style heads, can they just be swapped? firstgear Engine 16 01-15-2007 12:02 AM
305 Heads...Vortec or something else? Ozz1967 Engine 0 04-13-2006 11:47 AM
Exclusive parts for Vortec heads mgray Engine 1 10-16-2003 06:38 PM
