Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 vortec help
Thread: 350 vortec help
Old 03-26-2012, 06:43 PM
apexrig1 apexrig1 is offline
350 vortec help
I've been building a 350 for something to do this winter and finally starting to assemble everything and get her on the dyno. I used a 96 vortec block since I could take advantage of the roller setup and steel crank. Went with the pro comp alum heads and ported them. Got a flow of 295cfm. Thought that was decent for a low buck head. Camshaft is .525 lift about 230 duration @050. Flat tops should be right on 10:1 when done. Air gap intake. 750cfm carb.
Does anyone think I can get 450-475 from this setup??
And my next question!
Has anyone had troubles with the oil galley plugs from the federal mogul frost plug kit not fitting? They were way too small. I ended up installing a 19/32 plug but when it went in it pulled out with the punch I used. But it went in tight? Has anyone had this problem? Could a person tap and install threaded plugs?
