350 vortec horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 02:18 PM
I just bought a 1998 350 vortec it came out of a 1500 i have three questions 1. i think it will but will it bolt right in to my 1990 2500 with a 350 in it
2. im looking to get about 400 horsepower out of it whats the best way to do that
3. when i get it all rebuilt whats the best break in procedure
Old 03-20-2011, 07:20 PM
spinn's Avatar
Buy a package system. Summit has a Heads, cam, intake, gaskets, package for $1300 that claims 400+ hp. The Holley systemaxII claims 410hp, the RPM advertises 430hp. These are ready to bolt on speed kits, and go fast.
Check out the knowledge base section on breakin. Prime with 30 wt non syth, check for leaks at rockers and maintain oil pressure with pump primer , find the oil leaks as they happen , after a heat cycle or 2 the bolts need retorquing, twist the ignition distributor base with a sparkplug attached to confirm spark, cold time engine 10 before TDC, wet intake and throttle plates, Crank it up. Fluctuate idle 2000-3000 rpms with an apropriate setup of baseline carb setting, 20 mins of this, headers turn red and adjust timing and idle circuit, and valves or something like that.
Old 03-20-2011, 10:20 PM
cool rockin daddy's Avatar
Its already a Vortec so you have the Vortec heads. Stab a Comp Cams XE274 or equivalent into it (its a roller engine so many choices), put GM beehive springs or machine valve guide bosses on head to accomodate higher lift of cam, get an Edelbrock RPM vortec manifold, 750 carb of your choice. Headers, of course. Easy 430-440 HP.
Old 03-21-2011, 08:50 AM
is the cam a hydraulic flat tappet or roller?
Old 03-21-2011, 10:07 AM
You DO know what you bought, right? Your engine is a roller cammed engine. If you read my post you would be looking for a roller equivalent to the XE274. Something with the same duration and lift, give or take, of that cam.
Old 03-21-2011, 11:33 AM
ya i just didnt know for sure what kind of cam it was
Old 03-21-2011, 12:05 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
sorry to say but your power estimation here is a bit high considering that stock vortecs only flow about 227cfm @ .500", which still is pretty good but not 430-440hp from a moderate cam and 9.3:1 stock compression. other than that you are just about right on with everything else but the hp would be more in the area of 365-390hp (could possibly hit 400) which would put the OP right about where he wants to be. but without some port work done to the stock vortec heads this is about where you want to be. i also think the 750cfm carb is a bit overkill considering the motor wont likely see over 6000rpm. 750cfm carbs are better for a 383-up that will turn 5800+rpm or a 350 that will turn 6500+rpm
my advise would be to tear the motor down, have it honed, re-ringed, new bearings, (new pistons if you want more than 9.3:1 compression). take the vortecs to a decent head shop, have them do the required work to run a cam with higher lift, and some mild port work (these heads respond very well to some minor touch up). check the pushrods, and rockers to see if they can be reused, although i'm not a fan of COMP cams the XE274R is a pretty decent cam, you will have to run an aftermarket stall with it, then look for a set of OE style hyd roller lifters (howards cams make a great set of them for a good price) then look into a 650cfm vac secondary carb, and an aftermarket HEI distributor, new oil pump and water pump and you should be good to go for about 400hp/415tq with a great power curve (you may very likely need to get a shorter set of rear gears as well, nothing less than 3.42's or 3.73's)
Old 03-21-2011, 02:40 PM
327NUT's Avatar
87Z...I agree with with you except the 650 cfm idea and of course to each his own. I would run a well built Holley 3310 750 vac. sec.
Old 03-22-2011, 02:23 PM
what pistons come stock in the vortec? dished or flat topped? if dished what volume?
Old 03-22-2011, 02:27 PM
my87Z's Avatar
since the OP is likely going to use a dual plane intake then he would probably do fine using the 3310 750 vac sec carb, dual planes are far more forgiving when it comes to using a slightly larger carb. if he were to use the 3310 then he would likely gain a little peak hp but loose a little bit of low end tq (which is want you want for the street, not to mention this is going into a heavy truck so you should build more for low end tq instead of peak hp).
I went to holley.com to use there carb calculator, i plugged in 350cid/ 6200rpm max/ mildly modified/ 4bbl/ NA/ street use
it came up with carbs as low as their 600cfm vac sec, all the way up to there 770cfm truck avenger carb (vac sec). the majority of the carbs you will see though are 650cfm.
my strong suggestions for this build (besides what i have already listed above) are to use a 0-80783C holley 650 vac sec, elc choke, 4150 style carb. then to use a set of 1 5/8" headers instead of the 1 3/4" headers, as these will help to produce a bit more low end tq, and help to make a smoother power curve. true you may loose about 5-10 peak hp (all above 5000rpm) but it will make for a better throttle response, and a vehicle that is more fun to drive on the street
Old 03-22-2011, 02:55 PM
my87Z's Avatar
i believe that they are going to be a cast alm piston, and based on the vortecs being 64cc, quench being in the area of .040-.050" then the pistons are about -12cc dished. but the problem with them is that they use a round shaped dish in the piston head, we have later found that a D shaped dish with a flat quench pad has far better burn characteristics which means the fuel burns faster and more completly causing more force and efficincey with equals more power
if you want new pistons then i would suggest these.
http://www.kb-silvolite.com/kb_car/p...tails&P_id=157
KB102, which are a 7cc flat top, which when added to the average .050-.055 quench whould yeld you about 9.75:1 compression ratio. for what you are looking at doing i dont think you would want to go any higher than this.
here is a second set of pistons (probably the ones i would actually use)
http://www.kb-silvolite.com/kb_car/p...tails&P_id=155
KB193, which are 12cc D-cup pistons, these with your average .050-.055" quench will yeld you about 9.3:1,
but here is what i would do, i would tighten the quench area up to about .040 by measuring the clearance between the piston at TDC and the top of the block surface (i'm guessing it's about .015" ish) and then using the correct gasket (.015" + X = .040") about .025" to give me the tighter quench area. the KB193 + .040" quench area will give you about 9.5:1 compression, which for this build i think would be perfect.
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 04:17 PM
Vortec head horsepower Bracewell Engine 5 10-15-2010 10:15 PM
im converting a 96 350 vortec and putting in a 99 454 vortec rkoontz93 Introduce Yourself 1 05-11-2010 04:26 PM
Identifying Vortec from non-Vortec engines? RDR800 Engine 4 07-07-2006 09:09 PM
Horsepower.... and horsepower loss PonchoTA79400 Engine 3 03-13-2004 10:25 AM
