Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 vortec to tbi conversion
Old 12-21-2011, 10:44 AM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
You can do about anything...just depends on how much work you are up for. The thing with the 97 to 87 is that just about nothing electrical is reuseable. IMO, the best option would be to transplant the engine and transmission with every inch of applicable wiring, ECM, and sensors. I know there is alot of information out there on vortec swaps, but I am not an expert in the matter. However, if you transplant everything I suspect it will be easier than trying to "adapt" the engine only.
