Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 vortec to tbi conversion
  #21 (permalink)
Old 12-21-2011, 07:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by thekcbeast
well i actually have another option i have an older bare block casting # 3970010 that i also considered turning in to a tbi motor by using my tbi intake and swirl port head. nowdo you guys think this would be a better an more cost -effective build instead of going to the vortec?
That's all well and good if you don't want the advantages- and hassle- of using Vortec heads. But you'd also get a hydraulic roller cam and 1-piece rear main seal. To me it's a step or two backwards to use an older 2-piece RMS block and if it needs "the works", it won't be cheaper than the Vortec long block unless the Vortec needs everything, too.
I had thought this was a performance upgrade, not just getting something into the truck that will run. At the end of the day it's up to you to decide how to spend your time and money.
Good luck.
