350 Vortec to TBI conversion - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 07-03-2012, 04:06 PM
Edahall's Avatar
I've got a 1999 Chevy Tahoe with a blown engine and worn out transmission. I also have a very low mileage Chevy 350 TBI and 4L60E transmission out of a 1994 Chevy van. I want to put this whole 350 TBI and transmission setup into the Tahoe. I would like to keep it TBI if possible for its simplicity. How hard is this to do? I've got the complete wiring harness and computer for the 350 tbi.
Old 07-03-2012, 04:33 PM
LATECH's Avatar
Neither. Dont even bother. you are going backwards as far as emission devices go, it will never make it past a smog station.
Besides, you are talking a pretty major rewire on the Tahoe, then you will need to change the fuel lines as they wont fit, then the tranny wont work as it is probably a 4L60E, so it needs the PCM in the truck now , which wont run the TBI setup.
No sir, wont happen.
BUT, you have a perfect engine and trans and computer, man o man, get your self an Old chevy of somekind and build something really cool.
Trade the Tahoe in.You wont be sorry.
Fact is stranger than Fiction
Old 07-03-2012, 05:16 PM
Edahall's Avatar
Drats!! I was hoping not to hear this. I prefer the TBI over the problematic Vortec fuel injection setup. Smog is not an issue where I live. The engine and transmission only has 20k original miles on it. I pulled it out of the van back in 1996.
I already have an old Chevy. It's a 1972 Chevy truck but I'd rather put a Cummins in it. Yes, the Tahoe is hardly worth more than scrap metal but at least, it's 2 wheel drive so I can lower it and make it a sleeper.
Anyways, back to the 350. Can I put the Vortec intake manifold setup on the 1994 engine so it can work in the Tahoe? I would rather keep the TBI heads because they are virtually new.
Old 07-04-2012, 04:21 PM
You can use the old engine/trans with the corresponding ECM. You will have some difficulties with keeping the ABS and maybe the instruments working. ANd it will not pass even a visual emissions check.
Old 07-04-2012, 05:55 PM
The vortec manifold wont bolt up to your tbi heads if i remember correctly its wider, tbi manifold uses 12 bolts vortec uses 8 bolts.
Old 07-04-2012, 05:58 PM
LATECH's Avatar
Trade the Tahoe for a cummins, and get an old impala to put the TBI setup in.
You got stuff to trade with there, pony up on horsetrading a little
No pun intended.
Old 07-04-2012, 06:00 PM
LATECH's Avatar
That ol TBI setup would be super sweet in that 72 .
Old 07-04-2012, 06:12 PM
Edahall's Avatar
Yeah, that's maybe what I should do. The TBI engine should bolt up fine to the 4 speed manual that's in the truck. It's got an SM465 4 speed manual and 3.08 gears so overdrive is not really needed.
Old 07-04-2012, 06:34 PM
LATECH's Avatar
If the ECM you will use was for a standard shift you will be fine. If from an automatic you will need to change the prom or possibly the ECM to run a standard shift. I would bet just a prom would do it. That can be sourced from a salvage yard,or even the dealer may still be able to get it. Used to be like 45 bucks.
Also you may or may not need to run a VSS.
(vehicle Speed Sensor) some late 70 and early 80 models used one that went in the speedo cable to make it easy.
What ECM n umber do you have?
Old 07-04-2012, 06:58 PM
Edahall's Avatar
ECM is for an automatic. I have yet to pick up the engine & transmission so I don't know what number is on the ECM. However, I do know that it is from a 1993 Chevy van.
Old 07-04-2012, 09:21 PM
Wiki Edits: 31
Just get the TBI wiring harness for a 1987-1993? Chevy truck. easy to find, few $ at the junkyard. The transmissions were not electronically controlled except lockup, so it will work fine with the M/T..
SM465 was used thru the 80's and into the TBI years, there is a VSS out there to make what you have work..
Recent Modern Electronic Engines posts with photos
350 TBI to 350 TBI VORTEC SWAP IWANTMOREHP Engine 8 10-20-2016 09:57 AM
350 vortec to tbi conversion thekcbeast Modern Electronic Engines 26 05-07-2013 09:55 AM
350 vortec tbi conversion help Catatonic21 Modern Electronic Engines 0 06-07-2012 05:06 PM
305 vortec to 350 tbi 98chevystepside Modern Electronic Engines 3 01-16-2012 02:08 PM
350 vortec with TBI oldgolpher Hotrodding Basics 5 03-24-2010 11:42 AM
