I did a L31/TPI 355 with the LT4 hotcam kit. Strong low rpm and mid rpm torque. Have spun the engine to 7200rpm, but not making power up there.
You arent going to make much power with the stock plenums and runners. SDPC made 367 hp/406 lb/ft on their SDPC TPI.L31 crate engines. The ZZ4 cam will get you nowhere near your goals with 208/221 duration. To run over .480" lift on stock L31 heads will require 787-16 Comp Cams retainers and any Beehiove spring, 26915/26918, PAC beehives or 02-04 LS6 behives. Stock the TPI 305 ran 15.5@88mph, TPI/L31 355 ran 13.8@99mph on stock 85chip and 32 lb/hr injectors. Stock an L31 is rated at 255 sae net hp@ 4600rpm, and 330 sae net lb/ft torque at 2800rpm. That is roughly 310-320hp gross hp. If I did it again, it would be getting an LS1 or a brand new LS6 for $3200. peace Hog Last edited by Hogg; 08-25-2011 at 09:24 AM. |
What compression did you run on your engine? And thanks for the retainers and spring info, thats what I was wondering about.
Why didn't you tune the 85 ECM for the mods you made? I bet it would have run a lot better in the 1/4 mile. |
Think you are way off in your torque expectations. Are you using the MAP or MAF system? If you are using MAP, then you can not use a very radical cam with out a bunch of reprograming of the computer and even then not sure how good that would work. Also, you may have to go to 30# injectors to approach your target HP, another reprogam. On the up side, you can get a nice running motor with pretty good fuel economy.
Trees |
Im using MAF for that reason. The 3.1L V6 that my Camaro came with was MAP, and you could have so many MAP problems and go through hell and back to find out why the car is studdering to find out that your MAP like problem was one of the many other sensors that MAP is dependent on! Im so sick of MAP, and MAF is easy to tune, and its only one sensor, not multiple ones.
I found a build online that made 357hp at 4900 rpm with the LT4 hotcam and 24 ilb injectors, and SDPC said that they made up to 375, but didn't say what injectors they used. My torque will be close to 400 ft/ilbs or at least somewhere in that neighborhood. I'm going to eventually have to get high-flow runners if I want to improve this setup even more. |
If it were my car I would have tuned the ECM. ACtually if it were my car I'd stuff a 411 OBD2 PCM in it and tune it with Tunercat OBD2 that I use on my 97 L31 truck. I tell him to spend the $160 for a chip from Fastchip, but he wont spring for it. He wants to get a local dyno tune, but the guy will only tune it if he switches it to Speed density. b/s The car has a decently lopey idle esp. when warmed up, but hunts for idle excessivley at idle in gear, and will stall in gear A/C on at stoplights. This all in the tuning, less MAP pressure due to cam and the ECM is confused. The Iroc netted 1.80 60ft times with thestock 305 TPI TC and stock 3.42 gears. The car will almost dead hook with a WOT stomp from idle. Its a good all around combo, good low rpm torque, and decent 3rd gear pull. Even with the stock 305, thecar did easy OD burnouts with the 245/50-16's. He swapped out the stock 85 MAF from Granatelli and he says it ran a 12.8, but I havent seen the slip, so I am skeptical. That lower intake is $400US and the one I installed was one of the1st ones released and it took over 4 hours of mods to get it to work. Bolt holes drilled by not tapped, alignment issues. I have heard they are better now. I would think that 400 lb ft is attainable. A Ramjet 350 intake will work. I like this intake as well, under $200. http://store.edelbrock.com/mercuryme...ensorslot.aspx pic here of the marine intake I am using in my 97 L31 truck ![]() Here is a stock L31 Vortec 350 intake next to a marine intake ![]() peace Hog |
| Vortec 350 Cam suggestions | 69chevyLWB | Engine | 17 | 04-06-2011 11:22 PM |
| advice/thoughts/suggestions 327 build | 1968ccaammaarroo | Engine | 18 | 04-23-2009 06:23 PM |
| Advice? suggestions? 496 BBC build | 2wld4u | Engine | 1 | 07-29-2007 09:27 PM |
| 454 buildup; not happy- need advice, suggestions, etc!!! | Bob Turner | Engine | 14 | 11-25-2004 08:00 PM |
| need advice/suggestions | suede71 | General Rodding Tech | 2 | 09-17-2003 05:23 PM |
