350 vortec turbo install - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 08:54 AM
I want to add a turbo to my 96 3\4 ton with a 350 vortec the motor is fresh bored .30 over, balanced. I was wondering if anyone has done this before or if anyone can help me out with the parts i need to get to figure out the best and of course budgeted setup thanks.
Old 02-14-2008, 07:45 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I haven't done a turbo install, but I have installed a stage 2 super charger kit. I replaced the cam and lifters and replaced the rod bolts with ARP's. What a screamer that one was!
Old 02-14-2008, 08:23 PM
What was the effect on economy when driven normally?
Shane
Old 02-14-2008, 08:31 PM
My 2 cents worth
Wiki Edits: 3
I have never asked the customer that question yet. If you asked me I would say it had to be a lot better, because you did not have to put your foot into it very much to make that 4x4 spin all 4 tires. With just a light throttle it responded real well. I do know he had it on ebay for sale awhile ago, and I'll ask him next time he brings a vehicle in.
Old 02-15-2008, 05:13 PM
look into lower compression and like was stated a strong bottom end, i personally would use a holset hx35 found on dodge diesel trucks everywhere, will work for your size motor, and produce good boost to 5500 rpm and are relatively efficient a lower boost levels. and they are oil cooled, means easier on install. look into intercooling, a different intake manifold... an adapter can be made to fit ur throttle body on the intake. maybe step up to aftermarket efi. then get the exhaust to and from the turbos... ebay... sorry... is a great place for all this stuff
Old 02-15-2008, 08:02 PM
You might want to check this out, http://www.neufamily.org/truck.html I know for a long time he had a stock 350 bottom end. Im not sure if the info is still available but its a fun read.
One other note, don't do it if your on a budget and this is your daily transportation, expect to blow engines transmissions and rear ends.
Jordon
Old 02-15-2008, 09:15 PM
amen brother
Old 02-17-2008, 11:09 AM
Vortech 4.3's Avatar
jack of all trades
what fuel system in on it ?
ARE 305 and 350 VORTEC HEADS SAME badriand Engine 39 04-06-2011 08:40 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
Turbo 350 1980 Malibu Transmission - Rearend 14 07-27-2003 04:24 PM
Vortec for older 350? newchevyman Engine 9 07-17-2003 08:21 AM
