350 vortex heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2010, 08:48 PM
KzyCkr's Avatar
KzyCkr
350 vortex heads
I was reading old posts about my heads. my heads are at the machine shop getting studded and installing guide plates, on top of that are "Proform" 1.5 roller-tip rockers PN:66906c. harden one piece push rods and my cam is a Crane Energizer Cam PN:100052 with a lift of .454. i am planning on buying either Comp Beehive Valve springs PN:26981-16 or 26918-16. (numbers from Northern auto parts)
Now reading old posts an reading on www.chevyhiperformance.com i need to have my guide machined.
Any one have any pointers.
thanks for your time
Brandon
Old 03-13-2010, 07:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Maybe, maybe not.
Check out the info HERE. And you can do a search on Vortec heads here on this forum as well.
There are more ways to get where you want to be than cutting down the guide bosses. But doing so will allow more freedom to use a higher lift cam at a later build, and will allow the use of readily available seals.
Good luck.
305 heads with 1.94 valves on a semi stock 350? robbiesmechanic Engine 3 03-20-2009 09:19 PM
350 chevy heads question pena0724 Engine 7 03-02-2009 06:09 AM
Olds 350 1971 heads - valves - HELP! bandit79jun Engine 18 12-23-2008 05:11 AM
Piston preference for a 350 with 305 heads Old School Baja Engine 0 01-07-2007 07:23 AM
olds #5 head johann Engine 1 07-30-2006 10:05 PM
