350 vs 200r trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2006, 07:15 AM
350 vs 200r trans
I currently have a 350 trans in my 69 Mercedes 220 and would like to get something with a higher high gear. This car has a 4.08 rear and turns a lot of R's on hiway.
I need to know what I would need to change to make this switch and how high can I get high gear?
Old 08-19-2006, 10:10 AM
High gear is always 1:1. What you need is overdrive. The 200-4R is .67:1 overdriven, 33%.
The overall length and output spline is the same as T350.
Use the 200-4R converter. You will need to fashion a correct TV cable, bracket and throttle linkage. Get a dipstick and tube. Mount will be moved rearward
Old 08-20-2006, 12:27 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Don't forget the lockup. It helps 10% on mileage.
I went from a 200 to a 350 and it was a straight bolt in. I recall the frame already had holes for the mount relocation on this GM G body.
http://www.snopes.com/politics/soapbox/lamm.asp
Old 08-21-2006, 06:36 AM
350 vs 200r trans
Thanks to all for the very useful info.
turbo 350 trans not shifting out of 1st phillip24 Transmission - Rearend 3 02-25-2004 11:34 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
350 trans rebuild? jwart Transmission - Rearend 0 09-21-2003 08:06 PM
Trans for a 350 ramjet in 37 ford street rod cng41 Transmission - Rearend 0 09-16-2003 12:31 PM
Turbo 350 Trans Vacuum Signal? 54 Chevy Transmission - Rearend 2 07-22-2002 04:33 PM
