Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 350 vs 400 pontiac engine ID
Old 05-22-2013, 07:49 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: GTO Reproduction Hood
This page has pictures....much better.....
How to identify your Pontiac engine
Look at it closely.
You have to ID the block, then the date code. Then the engine code is the last step.You cant ID the block merely from the code on the front as codes were used for may different engines over the years.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
h0trod (05-22-2013)
