350 vs 400 pontiac engine ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2013, 07:21 PM
Recently bought a 69 Firebird and was told it is a 400 CU Pontiac engine. This is my first Pontiac and would appreciate any info as far as telling the difference between a 350 and 400. Thanks for any help I'm a new member.
Old 05-22-2013, 07:33 PM
if you beat my boat, well race
good luck trying to ID the block, i havnt had much luck with mine.
the most for sure way to find out is by pulling the heads and measuring the bore. however, there is only .005" between a 400 and a 455. there are numbers on the passenger bank on the front face and the rear casting below the head.
mabe youll get lucky!
you can also look under the #1 exhaust port for a cubic inch casting.
if it says 350 or 400, it would be a post 73 block(i know in the 70's they started stamping them, just cant remember what year)
Old 05-22-2013, 07:38 PM
LATECH's Avatar
Look on the back of the engine behind the passenger side cylinder head. There is a number cast into the block.
There are a few numbers for a 69 400. 9790071 is one
9792506 is for the RA IV
9792968 is the RA V
The first one is more common , the second two...not so much
A 9790079 is a 350
Look back there for the numbers.
Fact is stranger than Fiction
Old 05-22-2013, 07:41 PM
LATECH's Avatar
Here is a list
Pontiac Engine Block Casting Numbers
What numbers are the heads by the way?
Old 05-22-2013, 07:49 PM
LATECH's Avatar
This page has pictures....much better.....
How to identify your Pontiac engine
Look at it closely.
You have to ID the block, then the date code. Then the engine code is the last step.You cant ID the block merely from the code on the front as codes were used for may different engines over the years.
The Following User Says Thank You to LATECH For This Useful Post:
h0trod (05-22-2013)
Old 05-22-2013, 08:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Pontiac engine info
Pontiac info/sites
Old 05-23-2013, 06:36 AM
350 vs 400
Thanks for all the help the motor is in the car and I just haven't had time as of yet, hopefully this weekend I'll do some snooping around now that I'm armed with more info. Thanks Again!!
Old 05-24-2013, 09:20 AM
GMCBEAST's Avatar
Good call, my '72 400 is casted in the block on the drivers side also. Good luck.
Old 05-25-2013, 05:54 PM
1badLemans's Avatar
If all else fails pull the intake off and the "400" or the "350" will be cast into the lifter valley and be plain as day.
Old 05-25-2013, 08:05 PM
WDCreech's Avatar
Grumpy Old Goat Herder
"00" would be for a 400, "50" for a 350, and "55" for a 455. They didn't cast the whole number in the lifter galley. The easiest thing is to get the block casting number or the block date code & the block code that is stamped into the front of the block just under the passenger side head. Post those numbers and we can tell you exactly what you have.
The Following User Says Thank You to WDCreech For This Useful Post:
LATECH (05-26-2013)
pontiac 350-400 brandon301 General Rodding Tech 1 05-16-2012 11:21 AM
350 or 400 pontiac pontiac racer Engine 8 12-10-2008 09:54 PM
Pontiac 400 wider than Chevy 350 Goatman01 Engine 3 01-31-2007 12:11 PM
pontiac 350 vs 400 bb jjweb74 Engine 15 11-12-2004 02:30 PM
pontiac 350-400 swap 409guy Engine 12 01-13-2004 10:37 AM
