350 vs. 400 sbc
planning on doing a 400 sbc swap in my caprice but i been hearing alot of bad stuff about it. Overheating, cracking, ect. Never had one personally and need to know is it worth it, or should i just go with a trusty ole 350. All info appreciated. Thanks
Make sure the heads are drilled for steam holes and take care of the coolant. It's all a bunch of hubbub for nothing really.
ditto.....
Thanks. It has stock heads so they should already be drilled. Secondly, i wasn't really gonna take it apart, just drop a running block in.
dont forget the 'running heads'. and forget to keep your 4bbl carb and intake
Are you even sure it's a 400? Again! Casting number off back of block and the numbers on the front behind the altenator will help. And you'll need a different flexplate if it is a 400. |
Since this is a grocery getter and 400 will work fine. Most of the external parts will fit. Make sure the flex plate is a 400 type. I would not worry about overheating. The radiator sure handle it, because it's a low compression motor. Low RPM and Horsepower, High torque. There are Caprice out there with 400.
My cousin had a Caprice wagon with a 400 4 barrel Qjet. He had it for a long time and never had any problem. |
Agreed. 400 isn't "junk". People tend to squeeze them a little too hard without proper "prep", resulting in heating, cracking, etc. In a stock application, with a GOOD radiator, mixture and timing maintained, it's a good, torquey powerplant for a bigger car.
Jim |
| 350 or 400 sbc???? | cutthroatkid | Engine | 25 | 10-11-2009 05:15 PM |
| 350 or 400 sbc | cokeman277296 | Engine | 19 | 03-20-2007 06:39 PM |
| SBC: is it a 350 or 400? | 1984chevrolet | Engine | 3 | 02-07-2007 08:49 PM |
| 350 or 400 sbc | young_gun | Engine | 10 | 04-25-2005 08:42 PM |
| 0.060 over 350 sbc or 0.040 over 400 splayed cap sbc | tony350ss | Engine | 4 | 05-17-2003 09:02 PM |
