350 w/ 290k on it is dying, tips on making it last a little longer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2005, 09:35 PM
speedingpenguin's Avatar
Broke
My friends blazer has 290,000 miles on it, and its on its way out. Thing is, its his only car and he needs it to survive a few months longer before he can afford a new engine. Did plugs, wires, injectors, but that didnt help that much. Any sorta "tricks" to keep the thing running/maybe make it run a little better for a few thousand more miles? Thanks,
-Chris
Old 08-24-2005, 10:01 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
How is it dying? It is knocking, severely underpowered, smoking badly, burning too much oil or any combination of the previously mentioned? I think if a small block went 290k miles you cant ask for much more, thats pretty darn good.
By the way, my dads 73 pickup has 255k on it's original 350, it smokes a bit on startup but it runs pretty well.
Old 08-24-2005, 10:07 PM
BigDawgsEatFirst's Avatar
400SBC4Life
get the big hammer, out of the shed
at 250,000 miles
was time to start thinking of rebuild
Old 08-24-2005, 10:41 PM
larryblack's Avatar
Certified Lead Foot
there is a product called RESTORE. It will help the rings and guides to seal better. I put some in a slant 6 with 200k and evened up the cylinder pressures.
It may help get a couple of K's on the engine.
Old 08-25-2005, 05:35 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Larry, be prepared for the "mechanic in a can" wisecracks but personally I swear by the stuff, I used to be a non-believer but a friend convinced me to give it a try. The stuff definitely makes a difference. It cut my oil consumption in half and I picked up a mile or 2 per gallon on my 150,000 mile 3.8 and an annoying little "tick" at idle went away.
Old 08-25-2005, 06:08 AM
kstagger's Avatar
I put a can of Restore in on an old '83 non-rebuilt 305 I put in a cheap '81 malibu wagon -
seems to have helped with a little oil burn I was getting... it's no powerhouse engine, but hey, it gets the job done.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
chevy 350 making weird noises. v8s10 Engine 3 06-08-2003 12:18 PM
outting a sbc 350 back in with tranny already in car tips LoudMalibu Engine 16 02-15-2003 05:41 AM
ideas on making more torque in a 350 SBC stfinney Engine 5 11-04-2002 07:35 AM
Built 350 stops making power at 5000 rpm??!! chevyelc81 Engine 2 06-11-2002 10:33 PM
