350 will not rev on 3300 rpms - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2011, 11:08 PM
HOTRODtwan80s's Avatar
Hi everyone , can anybody help out , when I drive my el camino it will not let me get over 33000 before it starts chocking out until I get out of it ,?? In park I can rev real high , can anybody out , ???
Old 03-16-2011, 12:24 AM
DoubleVision's Avatar
Sounds very much like lack of fuel or plugged exhaust system. What exhaust system is on the car? Check the carbs float level, check the fuel pressure, fuel filter. Need more info on combo, is it stock? Street rod? What cubes?
Old 03-16-2011, 04:21 PM
350 will not rev over 3300 rpms
Its a 350 , its stock , with a edelbrock fuel pump, & 650 holley carb, & edelbrock intake also , LOL LOL its. My 80s hotrod . I have headers too with no cat, ????
Old 03-16-2011, 04:44 PM
Restricted fuel flow sounds most likely. As a test, temporarily remove any filter between the pump and the carb and test drive. While fuel line is disconnected, start engine and verify that you have sufficient fuel flow. Inspect the fuel line between the pump and the tank for restrictions, especially in any rubber hoses that might be sucked closed by the pump draw. Current pump gas in pretty hard on any rubber parts, and I have seen rubber hose separate the inner liner from the outer casing allowing the liner to suck closed.
Old 03-16-2011, 04:45 PM
Have you checked the timing, Mabe the advance is not working or stuck {vac-advance}
Old 03-16-2011, 04:54 PM
Bad coil, it happened on my blown 383 Vette!
Old 03-16-2011, 05:08 PM
CALI4N1A's Avatar
check for a carb vacuum leak (tightening or get a new gasket). A leak could stop your secondaries from opening under load -yet work fine when parked.
Old 03-16-2011, 05:19 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is it doing this during gradual normal driving acceleration or are you getting in it and when it hits 3300 RPM it acts up ?
Oh and if you are actually hitting 33000 RPMs well that's your problem. sorry i could not resist myself.
Cole
Old 03-16-2011, 06:12 PM
LOL LOL thanks , I ll check all that when I get home
Old 03-16-2011, 06:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be sure the choke is open, and not flopping shut. How old is the timing set?
What should my rpms be? prettyboyced Engine 22 12-30-2010 09:43 PM
no RPMs Blue Tattoo Engine 7 08-27-2010 10:27 PM
rpms down mkjarobinson Engine 2 11-19-2008 09:36 PM
Max RPMs? Doubleclutch Engine 5 06-03-2007 08:55 PM
rpms low77ride Engine 11 12-02-2003 03:56 PM
