Wont Start
Try checking the wire polarity. ( you can use a multi meter) The 12 volt coil connections have + and - on the end , positive and negative. The points are connected to the negative side of the coil with a black wire and when the points are opened from the closed position a spark should jump out of the coil high voltaqge cap end lead to earth or spark plug.( lay a spare plug on the block connected to the high voltage end ) If you slacken the dist. clamp bolt with ignition turned on and then rotate the dist. by hand back and forwards you should get a spark to jump out of the coil. Swap out the coil and try a second one to eliminate that. Points must be spotlessly clean. Drag a small piece of 400 or 600 wet and dry paper between them.
Cheers. Al. |
I wrote a wiki article on this topic. It should give you all the troubleshooting you need. here is the link Ignition Troubleshooting
Artificial Intelligence is no match for Natural Stupidity Chet |
| 350 sbc upgrade... Engine will not start | FenderGitars | Engine | 10 | 10-08-2010 03:26 PM |
| Help, long sitting 350 will not start | mwr0603 | Engine | 38 | 05-19-2008 08:23 PM |
| 350 Chevy won't start | Stretch3663 | Engine | 11 | 01-14-2008 09:29 PM |
| 96 350 vortec will not start | jeff_85 | Engine | 7 | 01-25-2007 10:22 AM |
| My truck wont start. 91 serria 350 tbi | montea | Engine | 17 | 12-17-2006 04:23 PM |
