Thread Tools Search this Thread share on Facebook
  #1
Old 01-28-2012, 10:07 PM
tcn71nova tcn71nova is offline
350 wont start
i have a 1994 chevy k1500 i replaced the passenger head gasket and put it all back together i have fuel and spark i pulled the number on plug and turned it over and have very little air comming out of the plug hole what does that mean
Register now (free) or login to remove ads
Old 01-28-2012, 10:49 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is online now
Last journal entry: Fresh paint
Wiki Edits: 9
Sounds like the valves are adjusted to tight, not allowing them to close on the compression stroke. That would be my first thing to look at. Is it backfiring or belching through the carb?
''Life's tough, Pilgrim, and it's even tougher if you're stupid.''---John Wayne
Midnight Sun Street Rod Association
Old 01-28-2012, 10:55 PM
it did backfire for a few turns now it just turns over and i can also wiggle the rockers
Old 01-29-2012, 07:04 AM
bondo's Avatar
bondo bondo is offline
Ayuh,... Did you Adjust them,..??
Old 01-29-2012, 02:49 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Too loose or to tight will lead to no compression. They need to be adjusted properly. There are many threads here on proper valve adjustment. Do a search.
Chet
Old 02-01-2012, 12:50 PM
thanks for the info guys it helped
Old 02-01-2012, 01:15 PM
T-bucket23's Avatar
Wiki Edits: 26
Did you get it running?
Chet
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "350 wont start"
ThreadThread StarterForumRepliesLast Post
sbc 350 will start run rough for a few seconds die and wont startfuel-junkyEngine912-15-2010 09:27 PM
wont startbig red 1Engine411-14-2006 08:52 AM
Wont start!wranglr88Electrical211-04-2006 10:36 PM
f-150 wont start please helpjumEngine802-03-2005 06:35 PM
wont startjeff germanoEngine103-17-2003 04:27 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
