350 Wont Start, Please Help!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2009, 05:04 PM
BowTiePride's Avatar
Chevy to the death!
Hey everyone. I know these are lame, and both myself and my Dad have treid everything else, but we are at our wits end. Here's the situation: I have a 355 sbc (350 bored .030 over, 194/64 heads remanned from GM Performance <was originally 305 heads I think>,Edelbrock performer intake man, HEI conversion, basic stock everything else) going into a 67 Impala, powerglide tranny. The HEI is wired straight off the battery (the 12V it needs) for now, so I just need to disconnect the negative between starts and when not in use.The engine is in, hooked up and wired up, it turns over fine, the fuel pump is working fine (filled a 2L pop bottle in no time), and she passed a spark test (alligator clips grounded to the intake man). I rotated the engine to 8 BTDC on the balancer, and inserted distributor so that it (rotor?) lines up with the #1 wire lead going from the cap, and lightly tightened down distributor. Stupid question, but I guess it needs to be covered, the #1 spark lead is the veryt front right lead (if you're looking towards the back of the car) right? I even pulled the #1 plug and inserted a wire to take sure it was 8 btdc on one, not six, in case the monkey with the engine before me mixed it up (I built it from a short block up). I tried 2 different Q-jet carbs, and still nothing!!! The occasional weak backfire, but nada. What am I doing wrong??? Any suggestions? I know it's not timed with a timing light yet, but with "half-***" timing, it should still run a bit, no? Thank you very much for your patience and help, Jake Engel
Old 07-12-2009, 05:21 PM
DoubleVision's Avatar
It sounds to me like the rockers are out of adjustment. If your positive the timing is set correctly and you have spark and fuel it should start so that leaves either a massive vacuum leak or rockers out of adjustment.
Old 07-12-2009, 05:26 PM
Chevy to the death!
I set valve lash to one full turn past just snug, and no visible vaccume leaks How can I check to see if the rocker arms are adjusted properly? Sorry for all the questions I'm just trying to go from square one you know? Thank you btw. I'll buy you a beer on the flip side
Old 07-12-2009, 05:47 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Are you sure your not a 180* off, TDC comes up twice in a 4 stroke engine,
you need the compression stroke both valves closed.
As for the #1 plug wire it doesn't matter what terminal it's on as long as
the rotor will point at it when at TDC, & the rest of the wires are
in order in a clock wise direction 8 4 3 6 5 7 2
Rich
Old 07-12-2009, 06:26 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It sounds 180 out i would recheck to see for sure. Cole
Old 07-12-2009, 07:05 PM
406 bug's Avatar
9.82 @ 139mph
Like they said , you are most likely 180 off. Remove #1 plug , stick you finger in the hole and turn the eng over until you feel comp building, that will be the correct stroke.
Old 07-12-2009, 07:48 PM
thats what it sounds like to me been there dont that
Old 07-12-2009, 10:14 PM
Chevy to the death!
Thank you all for your help It is greatly appreciated!! I timed it right, it was the valve lash was the issue, it was WAY too tight. I'm young and still learning, I thought I followed the engine manual but I suppose I did not!!! The Hemi Hunter fired right up, now for exhaust!! Thank you all so much again,
Jake
350 Chevy won't start Stretch3663 Engine 12 09-15-2013 10:00 PM
350 sbc upgrade... Engine will not start FenderGitars Engine 10 10-08-2010 03:26 PM
Help, long sitting 350 will not start mwr0603 Engine 38 05-19-2008 08:23 PM
96 350 vortec will not start jeff_85 Engine 7 01-25-2007 10:22 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 04:23 PM
