350C lockup plug wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2003, 11:24 AM
What is the correct wiring for the lockup convertor plug on the 350C? My failed trans [1980] had a 1-wire plug, but the replacement trans [1983] has a 2-wire type. Is it true that the front pin gets the 12v lockup feed and the rear one goes to ground?
Old 08-19-2003, 01:21 PM
DoubleVision's Avatar
as far as I recall yes, front is 12+ the rear is the ground.
Old 08-22-2003, 09:50 PM
If you want to be sure,pull the pan and see which wire goes to the solenoid inside the transmission. Can't miss it that way.
