350Chev- Can anyone help on a horsepower estimate? for - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2003, 01:39 PM
-sbc 350
-0.040" overbore
-ACL flat top cast pistons, 9.0:1 compression (Australian Fuel is of Low Octane Type), Moly rings
-Stock conrods
-Stock 2-bolt crankshaft
-Clevite Bearings
-Balanced Bottom End
-307 heads, very mild port polish / cleanup
-fuellie 2.02" int 1.6" exh valves, valvespring tension unknown
-Crow valvesprings(tension unknown), Crower collets and retainers
-Mellings High Volume Oil Pump
-1.5:1 Roller Rockers
-ACL Monotrque Head Gaskets
-Stock pushrods
-Cam Dynamics 0.465int 0.488 exh, .050" dur 224 int, 234 exh, adv. duration 290 int, 300 exh, Hydraulic Tappets
-Holley Street Dominator Intake Manifold, Match Ported
-650cfm holley mechanical secondaries
-MSD Billet Distributor, with Blaster 3 Coil
-Top Gun Race Series 10mm Leads
-Holley Blue Electric Fuel Pump, with Surge Tank Setup and Regulator
-Pacemaker Headers
-Rollmaster Double Row Timing Chain
-K & N air filter
Any estimates on how much power I could probably expect?
Cheers,
sbc downunder
Old 06-24-2003, 03:02 PM
E.T. divided by $ spent= Speed
Assuming that the 307 heads are prolly 993s.I'd say 335Hp
Old 06-24-2003, 03:50 PM
4 Jaw Chuck's Avatar
Somewhere between 200-1000 HP...but that's just an estimate.
Your results may vary.
— Han Solo
Old 06-24-2003, 04:06 PM
heads are the limiting factor
Your high vol oil pump is going to rob a few HP unneccessarily (do you really need it?)
