350cu.in.chevy motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 07:49 PM
My 350 cu in. chevy motor backfires and dies when put in drive or reverse!????
Old 01-30-2011, 08:32 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First, welcome.
Second, start a thread in the General Rodding Tech or maybe the Engine forum.
You are posting in the Site Suggestions and Help Forum:
"Discuss issues relating to Hotrodders.com in this forum. Feel free to ask questions, or post comments, suggestions, or constructive criticism. Specific tech questions should go in one of the tech forums."
Good luck.
Old 01-31-2011, 04:52 AM
poncho62's Avatar
Wiki Edits: 5
moving it.....
Sounds like you have the timing way off....or have a vacuum leak
Old 01-31-2011, 04:58 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you want to be more specific w/the problem, maybe someone can help- did it happen suddenly, under what conditions (warmed up, cold, ?), mileage/condition of engine...
A few things to check:
Vacuum leaks
Timing off
timing gear and chain badly worn or slipped
Carb filter or tune
ignition system general condition
Worn cam
Valves incorrectly adjusted
Old 01-31-2011, 12:32 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
This an automatic? ..."IF SO" then I'd guess poncho62 is right about the vacuum leak, probably the modulator diaphragm is leaking.
old chevy motor to new chevy truck pwchevyman1990 Engine 4 03-02-2009 12:36 AM
350cu.in. 430hp crate mtr I.D. redline427 Engine 0 11-25-2008 09:55 AM
What Chevy motor do I have ??? Ed ke6bnl Engine 5 03-11-2005 08:29 PM
chevy motor id 42361 Hotrodders' Lounge 1 05-16-2004 10:06 PM
350 chevy motor ridener Engine 3 11-22-2001 09:43 PM
